Full Car mods are :
ARE front mount intercooler with HPC coated pipes
GCG high Flow turbo ( Garrett 3076 turbine & compressor wheel, shortened heavy duty Actuator arm ) from GCG Sydney
Profec-b boost controller
Apexi Turbo timer
Auto meter boost / Vacuum Gauge
Auto meter oil pressure Gauge
Apexi SAFCII
Spal electric themo fan
3" exhaust System with stainless Cannon Muffler
Pod filter
Cold air induction kit feed from front bar
Blow off Valve
NPC custom Metal button clutch
Gates racing timing belt
Nismo short shifter
front and rear strut brace
Splitfire Coil packs
Body kit;
400r front bar
400r side skirts
Nismo wrap around bumper
black mesh inserts
wheels
18" Degeo customised polished alloy with black centre and Centre of spokes
car currently makes 276rwkw at 15 psi boost turbo capable of 18 to 20 psi but need bigger injectors & full pump
jesus...
so stock fuel pump, AFM, injectors and a piggyback computer?
I'd love to see the AFR's on that thing
i'd be looking into a Z32, nistune/PFC/vipec/haltech, 700cc injectors and an 044 minimum... ASAP
Long time dormant member, this is my current land boat (quite nimble for its size though)
Looking to get into another Skyline in the next few months though :)
Previous sled is in the sig below, miss it :(
This my R33 GTST
Hey I'm from here aswell, give me a wave/dose if you ever see me around, I know I've seen this thing around a bunch of times
Edited by G0DZLR
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
