  • Replies 176
250km/h for 10 minutes?
start work @ 3 in the morning?
I call BS.
for conversation's sake, a red hot exhaust is fairly normal. I've seen manifolds, turbine housings and dump pipes glow red, but if its anywhere further down the exhaust than that, then you have some serious heat, and a glowing exhaust is the LEAST of your problems...
seems only 1 person knows wot there talking about here, where did i say i was doing 250km/h(someone else said that) 3in the morning: yea i work in a mine u dork. my work is 120km away from my home, all straight with 1 S bend at 112km away from home. and ONLY the manifold was glowing red hot, where did i say the turbo and housing was glowing red hot. you should learn to read and stop being such a wanker. but ur bs still dont explain why its missing and farting. So stop trolling this tread if you dont know wtf your talking about
Edited by innocentdemon
If you're fair dinkum mate, I'd say this;
1. The glowing manifolds is pretty standard after a long hard run, especially visible in the dark. You probably wouldn't really notice them glowing in full daylight.
2. The missing and farting is likely going to be your coil packs failing. As they get old and when they get really hot they tend to open circuit and cause missfiring. If you haven't already done so, removing the cover (covering the coil packs) between the cam covers can alleviate the problem, or at least buy you some time (taking the cover off the coils lets the heat out).
thx.
since its a jap import alot of shops turn me away. would you know of a website i could purchase them from at a reasonable price.
in your first post you said you were at 6k rpms in fifth gear. in an R32 and R33 the final drive in 4.11:1 and 5th gear is .75:1. at 6k rpms thats 250kmh so STFU. you said yourself, I just repeated it. If you were in an R34, 5th gear is 1:1 ratio so you'd only be going 205kmh, so keep talking about who said what.
LOL @ OP. Snap at people for putting you in your place. Everyone here knows what they are talking about, you're actually the only one who doesn't hence you posted a question :down:
no you stupid dic i said i was doin 6k revs yes i didnt say the speed, and gear ratio to speed dont mean shit if ur goin up hill and also dont mean shit if your car has done over 400k kms and is a pos, and yes my clutch is a bit worn, and no i dont have a fcken speedo to tell wot speed i was doing, is why i said the revs and not the speed. typical aussie arogant bastards is all you are. i hope you serve to miss a cat and hit a tree. and yes i asked a question. thats wot forums are for you stupid fck. maybe you didnt relise this.
BAHAHAHAHAHAHAHAHAHA
For future reference (don't know why I'm helping you to understand, because you really are an arrogant shithead), unless your clutch is slipping something bad...engine RPM and gear ratio are 100% relative to vehicle speed. In a manual, this will not change whether you are going uphill, downhill or sitting on flat road. In an auto the torque converter will alter engine RPM a little but not enough for 6000 friggen RPM in 5th gear. And if that's the case, you have bigger things to worry about than a red hot exhaust manifold lol. Either that or you have an 8:1 diff ratio LOL...
I'm crying with laughter here.
And last i checked he isn't a typical aussie due to the fact he doesnt live in australia... hmmm.. Typical bogan thinking the internet is resricted to australia only..
this thread is completely full of win.. you're a douche.. you dont know shit and you bag out those who do.. go up a hill.. you slow down.. and so does the revs..
oh and the first smartarse guy who answered wasnt a aussie? i asked a question, i get stupid answers, my question was serious. i see how you guys treat other ppl.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
