Having thrown a few brake setups at the old girl, I am hoping this will be my last brake setup that I run for a while
Just need to machine up the mounts so that I can use the callipers with the new 343 x 32mm 32 vane rotors I have on order. Also waiting for Performance Friction to release the new compound of pad I am waiting to run.
Random brake fetish questions:
The Stop techs look all the world like F40/F50 clones. Do they share the same mount dimensions?
Who are you getting to machine the brackets?
Whose rotors you using.
Lastly these folk may be worth trying for pads:
www.polepositionusa.com
These are the DS2500 pad for F40's. NFI if they match the Stoptechs, however. Note the PFC cross reference.
http://www.polepositionusa.com/ferodo-frp3...-brake-pads.htm
They are similar in dimensions but as many differences as similarities. They appear to be forged rather then cast. The bolted bridge, the pad retaining clip is the same as the old school Big Red Porsche calipers. The pistons izes in these happen to be the same as F40s. I think mounting wise they have the same offset as the F40s, though will know for sure when I fit them up and trial them.
I am going to draft and machine up the mounts myself and going to use locally sourced 343 x 32mm 2 pce rotors
what size tyres are u running on the 34 rims roy, ive just bought a set from a forum member.
The car has standard guards atm so ill need to get them rolled as much as possible i guess since im thinking of re55s in a 245/40
what are your thoughts?
cheers
I just ordered some stoptech rotors from the states. Far out they are cheap vs brembo and harrop. And the Brembo/Stoptech floating rotor design makes it 100x cheaper to get hats mate up (no need for 20x $20 bobbins)
cheers
Mick, I run 265/35's on mine mate, no issues really, just a mild gaurd roll, kind of eats the inner gaurds a bit but no biggy. Edit: I just remembered it did actually grab the LH front gaurd once, but it was during a pretty rough road tarmac rally, hasn't done it since......
Edited by Marlin
  • 3 weeks later...
so ummmm, has it been on the track of late?
Any news on the plazaman, would love to see if my theory of standard runners will improve your response with a FF plenum. That or I have to take my inlet back to stock and see if I lose or gain anything.
Did a motorkhana the other week, but most likely its next track day will be the Sandown sprints on Cup Weekend.
In the meantime, new dump pipe with bung for the LC-1 A/F meter
The Power F/C isnt tuned to run off the A/F gauge, will see about getting a new one and installing to get the closed loop freeway tune more accurate but not sure if its worth the agro
Also now have my hands on my new rotors,
Mounts are drawn up and will machine them up out of some platic to see if the fit is ok before machining out of billet. Hopefully brakes will be all sorted in 2-3weeks time
Engine wise still waiting to see how dumping the plumb back gate goes for power and then we will try the plenum
Edited by Roy
You're a brake whore!
Your setup has the better rotors. But will be interesting to try these Stoptechs and see if there is much difference between them and the F40s. The Brembos have cheaper and better range of pads as the Stoptechs use Porsche pads and it seems anything with a Porsche part number costs that little bit more :banana:
I have a couple sets of spare calipers, Alcons and Brembos....on the lookout for a dedicated track car that they will find themselves on to. Have a set of 4 pot rears that I am building up at the moment that should work really well
I am hoping with the new plenum, Tomei cams, E85 and perhaps the 10cm housing that it will only lose 200rpm response and make 300rwkws with a good spread of torque for a 4,000rpm range. I still have the shorter diff that I can try to get this little 20 on song, but means i would have to go 19s or something on the street to get reasonable freeway cruising rpm. On my 17s it would be pulling 3600rpm on the freeway :D
Edited by Roy
hey roy
what size is that dump pipe? 2 1/2 into 3 or bigger?
and we have a stock internals rb20 down here pushing just over 300rwkw on e85 with a XR6 style bolt on garrett kit on a stock manifold. internal gate ect so you should get what you want on E85
They Harrop rotors and hats?
Dont believe so, but if they resemble Harrops then its not really surprising as the company making the rotors once had some ex Harrop people starting that side of the business. (what I was told back in 2005ish) They are CSC rotors.
My dump is 76.2mm stainless tube. Wanted to go 4 " but will have to get a custom reducer spun up to go from the small 8cm exhaust housing up to 101.6 tube. Will do that when I do my new exhaust.
I hope Caltex get some runs on the board with the E85, as otherwise I am considering trying one of the new TD05-18G turbos with ported shroud to fatten up my curve
Edited by Roy
hey roy
Wholeee bugeesus.... 300 from a stock internal 20! Whooohooo!!!
Hey Damo, is there any e85 servo's in Tas yet?
Cheers
Justin
hey roy
Isn't that car only running E30 ATM?
We run CSC's on the Targa GT-R, and apparently the rotors and hat are Harrops from the Harrop factory. Just a lot cheaper.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
