That centre console looks hot, did you have to customise the wiring or did you get a harness made up?
I bought a ready made harness out of Japan. Was a bit of a rip-off but it made it easy. As for the bootlid, I am not sure. I dont think it did. I have two bootlids, one plain and one with the modded R34 GTR wing. Not sure when pounting the wing whether the bolt holes need to be modified, but just looking at where the posts are I would bet a large sum of money the wholes are different
Took the car out for a wrap at DECA over the weekend. With the gate back to atmo and tune leaned on a bit more I am making 274rwkws at 21psi on 100RON, about 255 on 98RON.
One thing I really need to get on to this week is installing the Stoptech front brakes as the car is pretty lively in the rear with the std fronts back on the car :)
And a bit of a moment ...
I have some 700cc injectors to go in. But first want to understand if the plenum helps things, and then try another set of baby cams. With all that done then hopefully a more regular supply of E85 will be available. This is still my daily driver so availability of fuel is important
The car does really like the 100RON fuel, and atmo gate... it picks up a bit everywhere..
Next to go on now will be the plenum and then Tomei cams
Nice!
Guess that solves the mystery of loss of response with the 6boost manifold :P
f**k mate you are not having a good run. cams no good. the bloody sard rail I flogged you no good and the super fancy 6 boost mani still not as good as the trust one was. hope you still have the trust...
Car looks good as always. and f**k me dead as if we need brisby to have any more power than 275rwkw. that is about 200 more than you need you clown!
Oh well, was told years ago not to mess with it, I had stumbled onto a freakishly good setup for an RB20. But I am an idiot and like to tinker. So new IC, manifold, gate etc sees me with more or less the same power :) (probably still a tad less)
...oh, and as for everything being good in the world? Well, the car is back to trying to kill me which is fun. But bloody Belgium have gone quiet when i expected news by the end of last week so :thumbsup:
the count/bris alliance needs one of us here to hold the fort here in aus and garage the cars and one in proximity to ring and spa. tell them this is important business and pull their fingers out. lol. they are probably down the cas trying to win the bloddy toaster in the badge draw prize pool.
  • 3 weeks later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
