Yeh, when I went looking to replace my R31 GTS-X so many of the 32s I was looking at were in rather horrible condition and a bit tacky with mods and bits on them. I saw the 32 and the AVS wheels, very tody condition and just HKS filter and exhaust made me jump at it. So glad I did as the alternative was a red 300ZX TT and whilst I still have a soft spot for the ZED it woudl never have been able to grow with me and do all the things the 32 has as cheaply as it has
  • 4 weeks later...
First of all just read through the whole thread and god damn you sir are a pioneer.I rebuild turbos for a living so its good to see the real world benefits. Im also in the midst of rebuilding a 20det with a few bits and pieces to place in a 31. Just had a question as far as the 25 head on you're current setup did the head mods use the factory 25de valve spring retainers or they use the GTR ones.
Thnks for the read.
GLWTB
The valve springs are a question mark and they will soon be coming out and replaced with some Tomei springs.
Sadly the RB24 isnt going to happen. I plan on taking the car to Europe next year and need to save money so sold all the RB24 gear to another forum member who is cracking on with a quality build which I am going to be exited to see the results of.
Longer term I am being boring and going to put a std RB26 in it and engineer it all so that I can enjoy it on the street and track
Geeze, a real shame you'll only make it to a half dozen or so tracks... bastard. Impromptu garage clean up / sale to fund more?
Any chance of at least driving some of those brilliant roads you always read about in evo? Welsh hillsides, Swiss mountain passes, etc
I did 10 or so days of driving through the Swiss, Italian and Austrian Alps before importing my Sierra Cosworth RS back to Aus. That was back in 2011. Wow, how time flies.
I am going to Le Mans and Spain in a few weeks so planning on doing some of those Spanish roads EVO uses.
f5twister, Even if I have my gate atmo, which I doubt I will I dont think I will have much trouble with noise at Spa. I have only ever seen a few crazy loud race cars get pinged for noise...and seen loads of crazy loud cars run all day. Do you know any different?
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
