I know we're trying to get them translated and all, but who knows if/when that'll come through; fingers crossed it does but in the mean time I stumbled across these, and whilst there in Japanese I'm sure some of you want to have a look over them. Im still piecing bits and bobs together, but from what i can ascertain it seems to be pretty relevant to our interests. If you've never opened a PDF with Japanese fonts before, Adobe Reader may should you that you need the fonts & download them automatically (thats what mine did at least)
Basic Engine
Lubricated system
Cooling System
Engine Control
Fuel Systems
Exhaust system
Accelerator Control
Transmission
I hope Im allowed to post this? :)
Edited by Dunc
https://www.sau.com.au/forums/topic/332175-m35-workshop-manuals/
  • Replies 41
Awesome find Dunc :) This is a great help, I so needed this. I've been looking for something before I rip the intake apart as we still might have a long wait for the translation so this is just perfect.
I just need to find the interior & trim section now to make pulling that apart easier. I hate not having info for this, nothing worse than breaking a lug or something the first time you do it. Wouldn't happen to have this as well, that would totally make my day :) .
Awesome find Dunc :P This is a great help, I so needed this. I've been looking for something before I rip the intake apart as we still might have a long wait for the translation so this is just perfect.
I just need to find the interior & trim section now to make pulling that apart easier. I hate not having info for this, nothing worse than breaking a lug or something the first time you do it. Wouldn't happen to have this as well, that would totally make my day :O .
Roof
Exterior & Interior
Instrument Panel
From the 'Drive Line / Axel' section
Transfer
Front Axel Drive Shaft
Rear Axel Drive Shaft
Drive Shaft
Front Diff
Rear Diff
I'll see if I can work out the electronics section shortly :huh:
Edited by Dunc
Roof
Exterior & Interior
Instrument Panel
Transfer
Drive Shaft
Front Diff
Rear Diff
Dude, thank you, that is just so good. Ask and you shall receive. :O
Got lots of little things I'd like to do (& fix) around the car and these just make it so much easier & quicker. :P
Edited by Blade NZ
Basic Engine
Lubricated system
Cooling System
Engine Control
Fuel Systems
Exhaust system
Accelerator Control
Transmission
Hey Dunc to ease translation I need the original address .Can you provide- Brett
I hope Im allowed to post this? :/
see if they have the later model 'series 2' books also, there are 2 of them!
again, nice work on the find and additional PDFs!
Its only for the M35 models unfortunately. I can see if I can get my hands on something similar to the C34's, but I cant make any promises :/
And Brett, theres no 'original address/website' that I got these from, its from a disc which Im presumed is meant for mechanics or workshops. It has a web interface to schematics, but of course all of thats in japanese too. When I have time I'll try and get much of it online, theres a LOT of detail in them which Im not sure is necessarily in the PDFs Ive got (eg the pin out schematic for the ECU)
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
