Hel Stainless Steel Braided Brake Line Group Buy #2!
  • Replies 165
Posted Images
Ummm wasn't really planning to. If there was enough interest down the track I suppose I could. What were you chasing?
Hi,
you make for a Nissan 260Rs S1? ITS GOT The brembo brakes on it same as the R33Gtr. And clutch lines as well. thanks.
  • 3 weeks later...
I'm in if you are making another group buy, I thinking of doing this while getting my brake rotors replaced.
Car is a R33 GTS-T series 1
Nope no problems from any one that I am aware of (mine are probably free aswell) :(
Just a heads up if any one is keen. We did a small order this week and there is a spare GTST clutch and brake line kit. If any one is keen on them, let me know. If not my mate will be buying them after Christmas.
Cheers
Edited by PM-R33
Nope no problems from any one that I am aware of (mine are probably free aswell) :D
Cheers
PM sent ;)
If another group buy happens I'll be keen for some to suit r34gtt
I'd second that one!!! :P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
