Well.....
Just got home from powercruise and what can i say..
The Yellow R34 GTR wearing 'Nitto' plates took out the Powercruise dyno comp making a staggering 1017hp at the wheels. The car appeared to eclipse the 1000hp mark with ease and much to my surprise I later found out it was only using e85 fuel running a boost level around the mid to low 30's. The build quality of this car is impressive and looks like it means business with its GT47 turbo mounted forward of the strut tower in the engine bay. The car was built by Mercury Motorsport and runs a Red R Racing prepared Nitto 2.7 litre engine with the Nitto catalogue thrown at it.
Really cant wait to see this thing run more boost and even drink some race fuel and push the RH9 GTR at autosalon..
Congrats to Mercury Motorsport, Red R Racing and Nitto for putting on a good show and taking the trophy off the V8 boys.
Wonder if it can become the most powerful GTR in the world? :D
  • Replies 156
Very impressive indeed. Paul knows how to build em alright.
I also doubt it will become the most powerful as Mark's makes about 1400hp and Heat Treatment makes around 1600hp but it's certainly on it's way. That turbo is capable of more so I would have to ask the question, what is next on the list to open her up some more?
We definitely don't want to be the most powerful gtr, we just wanted to build a car to showcase our skills as a tuning workshop. It is a testament to everyone involved. I basically thrashed the car all weekend and the last thing on sunday put it on the dyno just to see how it would go.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
