i didnt know ppl were paying $3/L for e85. getting ripped much?? i thought c16 was expensive at $2.50/L
but on topic. i remember seeing this car before it was finnished (@ lakeside i think???) and thinking god damn thats gonna be fast!!
  • Replies 156
Trent,
Just like to say good luck at the upcoming Autosalon.
Having seen the process of the engine work im sure you will crack the magic number you are aiming for :)
Thanks Dave,
We were extremely happy to get 1000hp on E85, not sure if that had been done before, but to push it further now we are switching to c16 and more boost. The engine had perfect compression after the power cruise event, so we are happy to step up the power and see how it goes. Obviously the GT4788R is a big turbo, so there should be plenty of room to move from its current power figure. Fingers crossed it performs well at Autosalon. If it does, we will make the trek to Autosalon Sydney with a few more goodies added to it to go even further.
200hp @ 6000rpm, 800hp @ 7000rpm. :whistling:
Holy. Shit. Talk about a serious PUNCH, just a shame it takes so long for it....why so little power at 6000rpm though? I mean my R33 pulls harder than that lol
The engine is designed for serious horsepower, so there has to be a fair number of compromises along the way with the build to ensure it will handle what we plan to do with it. One of those compromises is response. There are many factors, but some of them are comp ratio, camshaft size, camgear tuning, exhaust manifold sizing, the size of the turbo etc. We will be compensating for this with a shot of NOS, to get the car onto boost, hopefully around the 5500rpm mark. That would make the setup a lot more enjoyable, although it is pretty freakin cool when it comes on! BTW, there is no lag between gears. It falls back onto full boost.
I'll bet its fun.
What secret spec cams are you running?
In all seriousness have a look at wizard of nos nitrous products.... they are light years ahead of the holley/NOS- NX- Nitrex etc. I've had first hand experience with Trev's gear on a 1800hp GT40 (plus nitrous) at some standing mile events and I have bought a full direct port set up for my own RB28.
http://www.noswizard.com/
It's exy- but it's well reaserched and tested technology.
Cheers
Justin
PS: check out the forum.
I'll bet its fun.
Big ones. :dry:
Cheers
Justin
We were just going to use a Zex wet, single fogger kit which we already have here, controlled by the ECU to turn on and off based on rpm and boost. For spool up, that should be pretty easy to achieve.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
