um yeah was just wondering if I can rock up this time without paying for the (AASA?) licence because I paid for it the last time but haven't actually received anything?? Was told it'd arrive in the mail (not sure how when you don't even have my address) so yeah...lookin forward to this
  • Replies 189
the asaa licence is a 12 month licence so you wont need to pay for it again.. you will have to contact either one of the execs or cams themselves to get a copy of the licence as they may not have had a addess to send it like u said. BTW your address should of been on the entry form
I entered as a N/A before the conversion..
see here:
you will have super throttle response and might end up being quicker than most of the turbo ppl
see how slow i am now!
p.s. START SENDING EMAILS OR FAX'S PPL!
You didn't mention to someone that you didn't give an address?
Best bet is to call AASA direct and tell them your address so they can send it. It's probably sitting on a desk somewhere ready to go
Just to confirm, AASA and CAMS are two different organisations. Either way, we accept both a CAMS licence or an AASA licence, and as AggroDave said, they're both usually valid for 12 months each.
wasn't going to do this one, not sure if my new car will be up to it but then I saw the courses. Can someone send me a PM about helping out? If you help out you can do a few runs at lunch right? That would be enough for me right now I think.
Yeah actually my address was on the competition entry form ... but I haven't received anything in the mail yet. Any chance someone can chase this up for me ? R34 with DR34PR rego plates on entry form.
The competition entry form, and the aaas form go to 2 different places. We just send away the aasa licence forms. You will have to contact aasa yourself unfortunately and chase them up.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
