yes, there are no synchros on reverse (and I think it is straight cut too?) It can be tricky to get first time sometimes, just let the clutch out in neutral then clutch back in and try again
^ yea what he said. reverse has no synchro so you must be stopped completely to engage it.
sometimes yea it will seem to not engage even though you've stopped, and often its just that your unlucky and have stopped right at the point where the teeth lockup against each other and wont mesh. if your on any sort of slope, let the car roll half an inch in either direction (or use 1st gear if on level surface and cant roll) then stop and try again. tends to work every time for me.
ive also noticed in some of my cars that are a bit older and start doing this more frequently when the gear stick is at the point where it locks up going into reverse you can get away with letting the clutch out only just enough to kick the input shaft around 1/8 of a turn while you have light pressure on the stick pulling back into reverse and you'll find it slots straight in. carry on
if reverse has no syncros, does that mean 1st doesnt either. when im slowing down to a traffic light i try to put it in first gear while im still rolling and it crunches. so im thinking it doesnt have syncros either??
Well if it was nineteen sixty soemthing & you were driving an MG then the chances are the gearbox wouldn't have synchros on either first or reverse. But being a vaguely modern car it does atleast have synchros on first.
well my gearbox is a nineteen sixty something :)
to engage reverse properly always select a further away gear first. Obviously 5th wont let you into reverse, yet if you select 3rd then 4th before selecting reverse you will get it in without the crunch.
My procedure: Stop, select neutral, shake stick, select 3rd, select 4th, select reverse.
Works every time in all 5 speeders.
Dilmah, dooo try it.
djr81 you mentioned something about a clutch draggin?
I have a kinda scraping noise (very light but still) when the clutch is out in neutral... bearing or dragging clutch?
hey i tihnk i have the same issue, slight noise when out, when clutch in noise goes away, only very feint though, so id like to know what the go is with this to
I think its the throwout bearing , mine does it too, mechanic said dont stress, so i dont...
However when it starts making a scraping noise when you let clutch out slowly in first, its on its way out..
My ute started doing this on thursday :banana:
Edited by Arthur T3
this
stop trying to smash reverse while your still moving, unless your doing motorkhana or something theres really no need
clutch up in neutral noise is usually input shaft bearing
clutch in scraping noise is usually thrust bearing
this
+11ty to all that
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
