  • Replies 44
not sure but I think he accidentally clipped the limiter once in there
I lol'd, yeah just a few times. A bit low on tread there at the end there too.
Ken hasn't excelled at WRC since he joined, still doing OK for a first year but he's doing a shit load better than Kimi
Ken Block is more than just a WRC driver, he's the creator of the DC shoes brand and an entrepreneur, hence why all his cars and vids have DC as sponsor.
If you guys have foxtel, check out Rob Dyrdek's Fantasy factory, he makes a few appearances with Dyrdek with the WRX and a Go kart called Gymkhana 2.1
Not sure why people bag the bloke.
If i had 20mil in the bank id be building crazy cars and doing stuff like that everyday :)
Id least with the sponsorship he would be making coin out of it.
I just don't think he has a ridiculous amount of ability, he seems like a wanker in a high powered car to me. Sure he's got decent skill but if I had hours a day to chew through tyres in a 600hp+ car I would be able to drive as well.
Want to impress me? Do it on a virgin track, with no old tyre marks from previous runs in sight. Do it in one take rather than splicing the best footage from several runs together. But maybe I'm just jealous because he's doing it and I'm not :blink:
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
