  • Replies 44
not sure but I think he accidentally clipped the limiter once in there
I lol'd, yeah just a few times. A bit low on tread there at the end there too.
Ken hasn't excelled at WRC since he joined, still doing OK for a first year but he's doing a shit load better than Kimi
Ken Block is more than just a WRC driver, he's the creator of the DC shoes brand and an entrepreneur, hence why all his cars and vids have DC as sponsor.
If you guys have foxtel, check out Rob Dyrdek's Fantasy factory, he makes a few appearances with Dyrdek with the WRX and a Go kart called Gymkhana 2.1
Not sure why people bag the bloke.
If i had 20mil in the bank id be building crazy cars and doing stuff like that everyday :)
Id least with the sponsorship he would be making coin out of it.
I just don't think he has a ridiculous amount of ability, he seems like a wanker in a high powered car to me. Sure he's got decent skill but if I had hours a day to chew through tyres in a 600hp+ car I would be able to drive as well.
Want to impress me? Do it on a virgin track, with no old tyre marks from previous runs in sight. Do it in one take rather than splicing the best footage from several runs together. But maybe I'm just jealous because he's doing it and I'm not :blink:
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
