Gt-r 40km/h Over. Need Your Help!
hehe this last page has made me giggle.
Interesting end to all of it.
I've lost my license before & by the same token beaten many many fanciful charges as well. If you've got the way/will to beat it, or use the law to your advantage. Power be to you for doing it. Sometimes the cost is not the issue, it's the principle of the situation.
If more people stood up to the absurd laws, contested their fines then the court system would become clogged and something would be done about the ridiculous revenue raising which is the driving force behind all camera operations. It's got nothing to do with safety at all.
That's when you say that you were under instruction of a police officer and therefore he can't do anything about it.
Yea I was going to fight, but lawyer f**ked up and it'd be another 3 months, so just decided to bite the bullet. We *might* have won, especially because it was only a small distance and low speed. *But* if the judge was in a bad mood he would rule against me.
Just so everyone knows, even given police instructions you *CANNOT* break the law.
I think some people really have no idea how scarily EASY it is to hit 40k over speed limit in *any* skyline.
Fixed. :P
Exactly.
Just because the government says it's right, doesn't make it so.
It's our duty, as an engaged memebr of society, to question and challenge our government at every turn.
Become complacent and before you know it you'll be working for your government, rather than your government working for you (as has already happened).
lol one court case @ a time.
I'm off to court soon over a parking fine. Dirty parking inspectors - I even got picture evidence of them giving out the false ticket.
Fkbags just assume most people roll over and pay - FK THAT!
details?
Said i was parked in non-standing zone, I wasn't. It'll be open/shut as i took pics of the car, the sign - where it was parked.
The works.
I could have sent a letter initially but fk it, clog the court system is my belief. Wont cost me money as ill move my shift so i can attend.
I used to park in one carpark spot all the time at Penrith - a parking bay on a curved laneway.
It was because the parking sign could not be placed on the apex to include that bay as "ONE HOUR PARKING". And the arrow could only start from the bay next to mine.
One day I caught a Ranger who was going to book me. I pointed out to him that the arrow and the sign could only refer to the bay next to mine and hence further down the line.
He walked away.
Two days later, I looked up at the sign, and a touch up job in similar green paint had been used to make the arrow point both ways.
Revenge is alive and well.
I swear: one day, I'll take a step ladder up to that sign and repaint ie. WHITE-OUT that section of arrow
He walked away.
I'd park there, and when I got a fine; take photo's of the clearly vandalised sign, and present that as evidence.
Rude B'stards!
If you have never done 40k over the limit then feel free to have a go at the op
other wise stfu
Its easy to get 20 k over in my wifes 1.6 auto laser let alone a Japanese super car
Man there are some righteous wankers in here, holier than thou much guys?
+ 1
he could have easily just done a stat dec but manned up and took it to court.
bigger balls than most.
Edited by hamiltonau
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
