  • Replies 106
Looking into the Bits o fishi turbo range .
Ok , Mitsubishi or MHI (Heavy Industries) call their turbo sizes firstly by the turbine family ie TD04/TD05/TD06 etc .
There are different turbines in each group and from memory there are four or five in the TD06 range .
They are usually (from memory) 11 or 12 bladed and one that gets mentioned a lot is the Trust spec TD06SL-2 one . Its easy to pick because its a bit smaller than most other TD06 turbines on the OD and the faces of the blades have a pronounced rake opposite to the direction of rotation . I think 11 bladed and a fair bit of cropping on them compared to many MHI turbines . You could be forgiven for thinking that Trust wanted them slightly lighter and smaller because they are dimensionally an in between TD05/TD06 families . They are favourite when high flowing the reverse rotation twin scroll Evo 4-9 TD05 turbos because the fit easily inside their re machined turbine housings .
MHI have quite a range of compressor wheels and common ones are the 16/18/20G wheels of which the 16G is std on Evos 4-9 and the handle is TD05HR-16G6 . It breaks down into TD05H turbine/R- reverse rotation/16G compressor/6 bladed , actually 6/6 meaning 6 full height and 6 splitter or lower height blades . From memory if their is a HR"A" it means it has a Titanium Aluminide or TiAL TD05 turbine .
The 18 and 20G compressors are just larger trim versions of that 68mm OD compressor group .
I'll get shot but anyway the Americans don't like the 20G compressor and TD06SL-2 combination in Evo turbos because they reckon it makes the turbo laggy initially . An American mob called Forced Performance (FP) made up their own 5/5 bladed compressor wheel to roughly the same dimensions as the Mitsy 20G and found it worked better , it was the now superseded FP "Evo Green" turbo .
I think you probably need to think Trust to get a Mitsubishi based turbo on an RB because I'm not sure if MHI made TD06 turbine housings with a T3 mounting flange and integral wastegate . From what I've seen trust use a 3 bolt mounting so I guess you need their manifold to make it happen .
I tend to think that the 20G compressor would work quite well on a 2.5L six provided you could get a TD06 based turbine housing and wastegate system happening . My gut feeling is that a 2.5L six should make reasonable torque right down low and one of the TD06 turbines would make a good match . I wouldn't cry if such a turbo didn't have the Trust TD06SL-2 turbine because they are possibly a smidge small IMO , more of a 2L four or six sized turbo IMO .
I don't know a real lot about Trust T67s other than they are supposed to be a combination of TD06 turbine and TD07 compressor ? I don't know anything about TD07's because they are beyond the Evo crowds sphere of interest . I have read a few posts about 25G compressors being a bit how ya going but why that is I don't know .
Anyway Trust kits appear to be the ones used on RB sixes so if interested search them .
As mentioned Mark at GT Pumps has the drop on MHI turbos in Sydney and would probably be the one to talk to .
Cheers A .
Disco makes a good point in that Trust td06's are 3 bolt triangle flange, when i was putting together my turbo kit for my rb20 i purchased the turbo off nengun thinking it was a t3 flange. When she arrived bang 3 bolt, 6 boost helped me out with a manifold and an ex gate.
Managed to pull 310rwhp due to overboosting, full boost by 3500-4000rpm on an internally stock motor, was an absolute animal to drive but at the same time enjoyable
Just found this thread.
Could always go the T67 and if it is too responsive put a 10cm exhaust housing on it. If you can get one for around $700 you are laughing.
An RB25 turned on the same read 'hub dyno' was running a T67 8cm listed by Trust for SR20, it now has the 10cm as he was chasing power.
The 8cm on a 2.5L auto would have similar response, but I'm not sure what gearing is in the diff, 4:11?. Should go nice.
Disco is right, the L2 may be a smidgen too small, unless you can get a 10cm housing later to suit, however the compressor side may hold you back then.
There is no such thing as too responsive imo lol.
Ill do some more reading on what it is I what, I know Trent loves the T67 on RB25's which on paper are very similar to the 1jz's, So hopefully he see's this and can comment.
diff gearing is 4.09:1 to similar to the skylines the the trans is a bit longer geared then the r33 autos.
Ok I have a bit of a list now
TD06H20G - Comp Inducer - 52.5mm Exducer - 68mm. Turbine Exducer - 58.8mm Inducer - 67.14 mm 11 Blades
TD06SL2 20G - Comp Inducer - 52.5mm Exducer - 68mm. Turbine Exducer 54mm Inducer 61mm
TD06H 25G - Comp Inducer - 60.5mm Exducer 78mm Turbine Exducer - 58.8mm Inducer - 67.14 mm
T67 25G - Comp Inducer 60.5mm Exducer 78mm Turbine Exducer - 54mm Inducer 61mm
TD07 25G Comp Inducer - 60.5mm, Exducer 78mm Turbine Exducer 62.9mm Inducer 74mm
So by the looks of that as said before the T67 would be the choice for responce, but Will more than likely Choke a 2.5L six.
So now Im thinking that a TD06H25G with a 8cm housing might be the go?
run a TD06sh-25g or t67.
I had a soarer on the dyno yesterday (VB on SAU's mate) and it made 270kw on 19 psi (not on my dyno as gate diaphragm was split, we only saw 230 @ 14psi) it had a 8cm TD06s-25G
if it was mine i would fit a t67 10cm, 280-330rwkw easy, stock bottom end will piss it in. Ive used these with great success http://cgi.ebay.com.au/Turbocharger-Mitsub...=item4153621750
Sorry, I meant more along the lines of getting compressor surge because the comp cant flow the air. Worded it wrong.
Interesting that my TD06H-20G is bigger on the hotside. Might explain why it did perhaps perform a tad better then there very similar setup L2?!?!?!?! Dont think it really matters but interesting to know.
Fair enough, I saw on ebay 3" inlet comp housing with anti surge slots, so ill pron grab one of those too.
Yeah I always though it was the other way around.
Do the T3 flanged ebay T67-25g bolt onto and standard manifold and clear everything?!?
As in could you use them as a bolt on option if you welded a gate onto the ass of the turbo?
Doesn't a T67 run TD06SL2 rear wheel?
Have a look all the spec's are here?
From what i can see there is no difference between a TD06SL2-25G and a T67 it looks to be the just Trust name for it?
http://www.skylinesaustralia.com/forums/post-a251041-
Already covered
yup, you just need to run a spacer, we found the std manifold to be a restriction though (fitted a/m one and it gained more mid and top) those turbos support 315-330rwkw at 19-20psi out of the b0x on internally std rb25 (no cams etc).
l2 wheel is cut back significantly.
Speaking of which, Trent do you know of any low mount manifolds for the NON vvti 1jz. I can find heaps for the vvti versions but none for the early ones, I want to avoid a high mount manifold if I can and dont want to muck about with adapter plates and stuff to fit a 2jz manifold.
I agree 100% great turbo for a stock motor, I have twins on a 26/30 and have a collection of them from tdo5-16g,18g tdo6 20g & sl2. They make huge power, are easy to rebuild, cheap and responsive. I have seen the kinugawa turbo on a stock rb25 and it hammered, not sure if it was the one above or this one Turbo seat of my pants felt like 300+ rwkw it was on a high mount ebay manifold and ebay gate too :ermm: cost him under a grand landed new a couple years ago.
Edited by rb30dett
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
