I've got no muffler and instead two pipes that run out from about the diff back...seen those selling in option mag b4, but no idea what they are called. Can someone tell me? Sounds very good but loud. Also have a resonator b4 the end pipes.
  • Replies 41
mrgts4,
your method is simple, but does it work, the big brand companys spend hours and hours on r&d and dynoing there products to make sure they work.
going with a shop built system may actually cost u hp.
i would pick a brand name jap exhaust everytime.
if the exhaust shop knows what they are doing then, there is no resone why they would not be as good as a big brand name...... the idea in an after market exhaust is to get better flow..... i got my one done as a coustom made one, it sit a lot high up than most big name brands and give just as good hp if not better....
i got a khs super dragger, and is quiter than most out there...
Had the EPA do a test, and it registered 87... (cat back only)
Thing to note though is that if you change the cats and dump pipe, it will be louder than just a cat back...
You can pick up cat back exhuasts pretty cheap...and most decent exhaust shops know how to weld and not to bend a system to much...
the only real "Japanese" part I would invest in due to the R&D is the muffler and dump pipe as these two elements contribute significantly to flow. Add to this the flow of the cat and resonators and the rest is JUST pipe...pipe is pipe is pipe.
I currently have only a 3 inch cat back bolt on system from 5 Zigan...bloody big rear muffler but nice a quiet, does have a crap resonator that I am removing shortly the whole system is modular so I can get a section made without a res, bolt in for some occassions and bolt in the straight pipe for others...flows 100 times better than stock yet to dyno though...
I have done the same. At the moment I am using a twin tip stainless straight through muffler from JustJap. 3" inlet and dual 2" outlet. Looks quite stock but sounds very nice.
Two 2" outlets is smaller than one 3" outlet....
surface area of circle = pi * r^2
So for 3" outlet = pi * 1.5 * 1.5 = approx 7.07 square inches
And for 2 2" outlets = pi * 1 *1 * (2 pipes) = approx 6.28 square inches
So your tip is essentially the equivalent of a 2.8 inch exhaust
Anyhow, I cant speak for any other type of exhaust, but the HKS super dragger is great in terms of noise. Very quite compared to a lot of others, and I dare to guestimate that it will fall within limits. Only drawback is that it hangs rather low, as the pipes have minimal bends in them...
Hmm... this just makes me think "why buy a pricey name brand catback when you could almost afford a 3inch from the turbo and a decent tip?".
I spent 1300 at western mufflers in fairfield. got a 3 inch mandrel bent zorst from the turbo back with a 5inch tip, is shiny too. Not too loud, good power looks good too.
if your even considering the high end name brand cat backs just save some cash and go all the way from the turbo with a no name.
I paid $250 for my HKS super dragger + $20 to weld a flange coz it was previously welded onto the cat for some reason, got the front and dump from Hi Tech in that group buy a while ago, and the 3" hi flow cat from BATMBL when he had the group buy going, installed it all myself, so I paid well under $1000 for my whole system.
Sure if you got an all new jap brand fron the turbo back and got someone lese to fit it, it would cost you a pretty penny, but if you look around for a good bargain, I'm sure, and have proven you can do well for a good price!
I tend to agree with bobjones here. I think the important parts to get brand names are the muffler and dump, because as he said, the rest is just pipe. I'm still deciding whether to get a split dump or a single pipe as i've heard a few mixed reports about the split dump doing nothing, and others saying that it gives them a decent increase.
After installing a CES split front/dump pipe I couldnt recommend them enough. Build quality is awesome and my car gained 7rwkw when running 2psi less boost. They're a bit pricey but worth every cent IMO.
The front dump if it is split, has to take into account that there is going to be some cross flow from the internal waste gate and the other pipe, it is vertually impossible to completely separate the two, thus why large turbo's run external gates. CES have developed a really good product and have put several on 200's with very good results. i intend to get one as they are comparable if not better than the HKS items, and add to that the ease o dealing with an Aust co.
However, saying that the Aust muffler, most of which are cannon style which I hate with a PASSION, are crap, I really like my fat arse muffler will post a pic if I can find my digi cam...
:( Einstein!
Im quite aware of this.
Just for those who think a 3" exhaust is a 3"exhaust, I know a guy who owns an R32 GTR, had a cat back locally made (jap one died) and it just felt lifeless and doughy by comparison.
the locally made 3" exhaust was removed (they used local flanges when it was made). the dump looked ok, so it was cut at the right length and a jap system fitted from there back.
result, car was back to its old self again.
they may look the same, but it doesnt mean they are the same.
before any of you that have had local made systems fitted gets upset with me, I am not saying YOUR system is bad, just sharing an experience with someone who wants to ask the question.
:( Einstein!
dont get upset now, I was just pointing something out.
I dont know you, so I have no other way of finding out you knew this.....
If you knew though, I'm curious as to why (other than the sleeper look) you didnt go for a 3" tip?
Piping also isn't always piping. The surface quality inside the piping can affect exhaust flow. When you put an silencer on the N1, you lose a little top end power, but gain some mid-range torque (according to the APEXi website). It supposedly drops the noise level by 7dB.
I agree. just put an N1 silencer on today. I can't tell of any power drop, car drives the same way but with a more EPA & "fussy neighbours" friendly sound. Didn't test the noise level with the silencer on though, would love to know someday.
Mine is basically a bits'n'pieces system. Started off with a Fujitsubo cat back 3 inch system. Was pretty quiet, but the muffler was baffled and it didn't do a great deal for horsepower. Had a 3 inch dump pipe made up and a 3 inch high flow cat fitted. Still quiet, a fair power gain. But on Monday I went the whole hog and had the resonator chopped out, a piece of pipe welded in and swapped the muffler for a 3 inch cannon with a 5 inch tip. So it's all basically straight through except for the cat. Theres a few bends here and there, But I don't think I'd really notice the difference if they weren't there. Rumbles a fair bit even when your idling along. But it's not too bad. Hasn't brought any cop attention yet (touch wood). But when I floor it, damn does it howl!
Sorry for biting your head off there.
I just did it to be different. To attract less attention (it may or may not succeed in doing that) and because I like the appearance of two largish stainless tips.
Overall flow is probably down on the average 3, 4 or 5 inch tip but im sure there are other factors in the exhaist that are more restrictive like my cat-convertor which make the overall difference trivial.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
