Well all that was an interesting read, dyno time will tell. I have some cameras including an endoscope so it will be easy to have a look on power runs. As usual I'm not chasing big power out of this new engine and if we see anything over 300 kilowatts we will be turning the boost down.
More updates, turns out my neighbor was a sign maker, so I bought some carbon wrap and got him to do the door trims that were in desperate need of a re-fresh, they turned out awesome.
I made a cable for the boost controller, so I can change from low boost to high boost from the steering wheel and make it so I can remove the wheel completely. I was just going to use old school phone cable but thought the wires were too small so I found a 240volt cable in ebay. Now to search all my boxes and find the horn pad and wire up the horns which I'll need to buy.
  • Like 5
  • 8 months later...
On 13/02/2023 at 5:03 PM, Neil said:
...Just as a heads up, I will die before Cheryl is sold....
So it turns out that is indeed what happened, and as Mel is not taking up racing and nor is their only child Lizzy the Great Dane, I am tidying the car up for sale.
As far as I can tell it is pretty much ready to go to the dyno for run in and tune, but I'll update in here once I know more.
  • Sad 6
So, starting with the rear brakes.
They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350.
Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff
Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
  • Like 1
Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well.
No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
  • Like 2
yeah for sure.....remember to put your tools away at the end of each day kids!
Actually it has been kinda nice working on the car, lots of memories of good times. I can pretty much hear him telling me off for stuff still.
Next, shocks/springs/swaybars
It has Sydneykid valved Bilsteins with HKS pillow ball hats all round.
Springs are Eibach race springs on adjustable height platforms, with helper springs in the rear to stop rattling. These are 250 all around but easy to change for something else if required.
Swaybars are powdercoated blue but would be Selby's/Whiteline solid adjustables, 21mm rear and 24mm front. Bushes and links in good condition
All in good condition, no sign of leaks/damage etc
Front lower control arm is standard with new ball joints, tension rod looks like JJR spherical. Front upper control arm is standard with adjustable bushes in the outside end
Rear arms are all nismo, surprisingly all the bushes at either end look standard but in good conditionimage.jpeg
Subframe has standard bushes with lock collars
HICAS has a lock bar with standard ball joints at the hub end
A few other things to round out the chassis mechanical checks.
Diff is nice and full of new oil, pretty sure it is Castrol VMX (I run the same on Award's recommendation). I didn't pull the cover to check, but I'm 90% sure the diff centre is a nismo mechanical (old school, not the gt pro).
Gearbox is also nice and full of fresh oil, not sure what it is but not redline.
Tailshaft bearing looks OK and a tailshaft loop is in place
Did a coolant pressure test overnight and it was back at 0 by morning....after some stuffing around I worked out it was the water return fitting at the turbo that was leaking, it all held pressure correctly once that was nipped up.
No brand mark on the radiator but I'd bet it is a 40mm cooling pro, with standard clutch and fan
I do need to remember to change the water out for coolant once the engine is run in but otherwise cooling looks all good.
2 minutes ago, fatz said:
How much ya asking drunkan
I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body.
Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right.
Everything else up to the throttle body was good.
Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt.
BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF....
Coilpacks are Splitfires with a factory loom in reasonable condition.
I didn't pull one put I bet the spark plugs are new as its a new engine
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
