link for people with no google skillz
mustangs still read higher than DD by a bit, but the results are comparable as far as ramp and peak power go (within a few %).
Good find.
I find it interesting that they are already making application specific housings before they even have a full roll out of the std housing options though...
It would be nice to see this option with a T4 TS IW housing on it.
Originally it was a consideration for my own project, right till I found they cancelled the plan for T4 TS IW housings on the smaller turbines.
Even if it were to make 450whp on 98 the response is excellent, we would all be out ordering gateless 6boob jobs me thinks.
Good find.
There is some parallel dev I suspect, Cosworth were working on them before ANY options were available. And cheers for posting the link, I had been having issues with my browser and ended up with a "CBF, do it later" moment. I figured I'd said enough to give the proactive googlers something to hunt for :)
he is probably waiting till he gets some good results before posting anything :P
Geoff currently doesn't have a turbo on his R14. His car has been sitting in his shop since the Modified event last year.
The Blue R34 in Borg Warner's booth had an 8374 twin scroll in it. The results haven't been posted yet because the owner of that car has not put in on a dyno yet. There is also an RB26 that has the twin configuration on it with the EFR 6258's. Not sure if there are numbers on it yet either, but the biggest concern for most is that they DO NOT SHUFFLE. I've had a few twin turbo set ups on the RB26 and anything that could produce over 550whp seemed to "shuffle" (surge)... so that was good news.
Edited by TheKeeper
well I have ordered a 9180 EFR TS housing (twin ex gate) back in november 2010. still waiting but it should be coming soon. I will do my nut if bumhoe gets his first though! we ordered and paid last year!!!
pretty keen to see it go. hopefully it'll be the first in aus. :)
Ordered my 9180 mid november too. Cant wait to get the damn thing. Where did you order it through?
Well i rang GCG turbos today and some guy told me they are still 4-6weeks away to arriving due to problems in US.
this is really fustrating cause i cant do anything until i get this turbo.
2weeks ago i was told it should arrive within 4 weeks. :/
Is geoff at full race ever going to post results of his personal rb26 + efr set up?
Probably why nothing posted ....new build with motor 7 inches rearward.
http://www.nissanroadracing.com/showthread.php?t=2680
A) Twin EFR 6258, on a 2.6L RB26, tomei 280 cams, mild headwork, stock intake manifold/tb
B) Single EFR 8374 .92 a/r, Full-Race twinscroll manifold, on a 100% Stock RB26, Tomei Poncams are the only engine internal modification.
I know that dyno reads notoriously LOW, and I think the single was found to have a boost leak which is why it wanted to drop boost up high. The torque curve looks nice on the twins, but I agree with Lithium we need more boost to see what they really do.
We're you hear that? I pulled the pics off GTROC, but there wasn't any other info.
I know the tuner, and know that dyno. I also know that those pulls were in 3rd gear, so it looks less impressive than a 4th gear pull. It's getting HOT in AZ so 4th gear pulls on that dyno really work the cars harder than necessary. I'm sure Geoff will post up when he gets a chance, he's up to his ass in the new race car build over there at Full Race.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
