I looked into actual 2860RS' (instead of the high flow I had), 2871s, 2876s, 3071s, T518zs, TD05s, TD06s, RX6s, etc etc etc ad nauseum, I now know more about those than I'll ever have the need to, while the 6258 may not be the best 'bang for buck' for most punters, for my dollar, it was the only way to go.
As you go along, can you kindly list items you have bought or modified in order to get it running well?
It would certainly benefit the whole community.
Sure thing. :)
The list so far,
Manifold (not strictly necessary)
Intake pipe
Outlet pipe
Dump pipe
Water fitting on the block (comp cover fouls it, yet to trial any solutions)
Oil drain line
So far that's it. I can't foresee any other issues aside from those. But I'll post them as they come.
4) The BP ratio should be intake pressure higher than exh pressure, until approx 5500rpm. from that point to redline, it should be 1:1
Geoff,
From reading around maximum is 2.5:1 ex/in pressure ratio. I have checked with the matchbot for both the 6255 and 6258, both exceed your 1:1, ratio. They are 1.6:1 and 1.5:1 pressure ratios, respectively. From talking to several tuners. This is optinum.
Ultimately I been trying to compare them to the GT2860r-5's, and if they fare well I will purchase a pair of EFRs.
I could use help by a dyno chart of either 6255 or 6258, and the boost graph included. This would help my decision matrix.
Thanks,
Joe
Edited by Sidwysracr
Sure thing. :)
The list so far,
Intake pipe
Outlet pipe
Dump pipe
Oil drain line
Is your motor built? If not, what is your expectation for things breaking down? Including your said manifold.
I may be running an SR soon and am out of touch with their capabilities.
Unopened. :)
I played with the idea of a simple rebuild while I was waiting, but knowing how things snowball, I decided against it to save my bank account.
Only internal modifications will be a set of BC step 2 cams. I'll likely go back to standard manifold, don't much like the design of the A'pexi.
Aiming for 250 on a nice safe E85 tune. Another 30 or so before I start worrying about the bottom end.
My only concern at this stage is the gearbox. I reckon I'll lunch that well before the motor shows signs of going to the scrap heap in the sky.
well I have some news. have a set of 6258s for a GTR on the way now. :) Full kit with full race manifolds, twin 6258s etc. This particular car has run -5s and -10s so it'll be a great comparison. I'm hoping for -10 power with -5 driveability.... I think they'll deliver but there's only one way to find out..... bear in mind they are quite a bit of airflow. 44lb each is a lot of powa for a little 2.6L engine.... :)
Keen to see results here
So twin high mounts? How 90's JDM of you Mr Baron!
lol. they should be awesome.
Consider this. look at the EFR range and consider the 9180 flows 94lb/min. a single 6258 flows 44lb/min I would say it's not unreasonable to expect them to produce 80lb/min combined in a twin GTR set-up. that's 800hp of air.
the car they are going on has run 2530s/-5s and made the usual 350kw or so. it's also run GTRS/-10s and made the usual 400+ kw but with typical surge down low that's a pig to drive through (even on the track).
I would like to think these will be close to the -10 power but with close to -5 response. I wouldn't be disappointed if they make a little less than the -10s but without the surge down low and with fat midrange.
I'm not sure if anyone else has bought a set from full race for a GTR apart from the one in the US they tested on. so this may be the first 'retail' set that goes out the door.
hope to have them arrive next week.
The other turbo I got from BW/FR is here and has already been pipped up etc and should be running very, very soon. it's the big boy 9180. another mate of mine has a 8374 coming soon so it'll be interesting to compare the 3. in power terms it goes 8374 then twin 6258 then single 9180. I'm keen to see if that's how it plays out in real life and what kind of power/response compromise we get. the only difference really is the 9180 is on a 3L the other 2 are both 2.6.
Unopened. :)
Awesome. I might 'boost it till it blows' with mine and see what comes about. Its been making 200odd @ 14pound since I built it in 03ish so it will be interesting to see how it likes more lol. Having a 4 pot again reopens my interest for the EFR, cant wait to see yours in action!
Also super keen to watch Beer Baron pioneer the SAU EFR stage!
Twin high mounts? what is JDM about that lol...
Think pre hype era, when a modified GTR was very much jap territory. Then think big twin kits... What was available back then? Some pretty ordinary garrett stuff and the ageless TD range.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
