It's an RX6 on the Cyber isn't it ?
I wonder how they stack up.
Always been a killer turbo, search rx6 in SAU and im sure i will have a post or two in there... used them for years.
Nice, where did you find the speed info? Shame the car had hg issues, sounds like there was supposed to be a final ace up their sleeve.
There was live updates and news on the WTAC site, And my family was helping with the Coote's S13 that Earl Bamber was driving, So I was getting plenty of texts from Sydney.
Edited by Sub Boy32
There have been a few people making aluminum replacements. We've have them for awhile. We left the center with open an 1/8"NPT thread so you can add your preference of barbed nipple. (straight, 90º, 45º, etc) Cool addition. BorgWarner makes one as well, but it is a block off plate vs. replacement.
Edited by TheKeeper
Yeah there have been some pretty excellent builds using them over the years, but I mean how they stack up against an equally rated EFR turbo ?
Its concerning that 8 months on from the point that they started leaking into the market the confirmed failure versus performance proof ratio of EFR turbos I've found is worse than the likes of XSPower etc. If this murmur of failures from the event proves any truth it'll be more like 50:50. The best results I've seen from them so far make them no more attractive to me than the Forced Performance HTA turbos, and at a higher price.
Its definitely bad enough that there is now no way I'd recommend them to anyone, price aside - unless there is eventually a convincing amount of good results over a period of time.
I hope people start having better luck!
hey guys, yeah obviously I can't share everything. we are 'testing' which means stuff happens.
anyway, lithium, neither advan/hi-octane RGM car had EFRs on for the weekend. we desperately wanted one on the R34 but ran out of time. we had a few problems (in fact a series of them!) like hold up in customs, run around with courier company etc and basically just ran out of time to do anything other than pinch a turbo off the R33 and stick it on the R34 (the 33 happened to have a T04Z on it). it was down on power compared to both the twin 2860 -10s and compared to the 9180 we had tested which was a shame but it still performed well. The R32 has been running 2860 -5s and we hadn't intended to run anything different. That car got very little development between last year and this year due to a few reasons mainly because everything was focussed heavily on the R34 development.
The R32 GTR entered by John Bright (BPG car) was running the twin EFR 6258s and ran well. He was only there on Saturday and a had a few small problems with the car (tyre problem, some suspension issues etc). To try and ensure reliability he ran the car with just 18-20psi (as opposed to the 25+ he'll eventually be running) but the car performed amazingly well considering. It's making more power than it did on the -10s and response is as good as the -5s. Please don't take this as gospel (my memory is full of figures right now) but it's currently making over 500hp atw on 20psi. John was put behind due to all the work involved in converting over to the EFR turbos and problems with supply etc (well documented and discussed in this thread) so didn't get to fit any of his aero gear, nor test the car etc so he put in a HUGE effort just to get there on the Saturday and compete. His tuner Phil (Armour Motorsport)and Mick at Corse Automotive also put in many late nights getting these things sorted. We also got some help from Brett Lloyd at GCG. Which was great as our problems had nothing to do with him.
Anyone who saw John's car coming down the straight would not have doubted that is has some good stonk. I took some time out to run down to the exit of Turn 1 and watch him powering out of T1 into T2 and he was very committed and the car looked quick and sounded awesome. It also looked very fast coming out of turn 2 and turn 3 which are slow-ish corner exits.
Once the current issues are sorted these turbos will be fantastic.
The Full Race BOV covers are nice too and not expensive. I'd recommend anyone using any type of EFR turbo get some as they make the turbo's look much nicer and eliminate any chance of snapping off the nipple. I like the one posted before too, looks very cool in bare alloy but I do prefer the design of the Full Race one as it doesn't have the nipple built on, it has a 1/8th thread cut instead so you can fit either a nipple or -AN fitting and means you can fit a 90degree fitting which is handy on the twin set-ups especially.
Anyway, still lots of work to do but things look good so far.
SSE were running their EFR 9180 and to the best of my knowledge they were the fastest car on the straight at something around 280km/h. There's no doubt the potential is there.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
