How do you guys running the EFR turbos find the boost recoveries between shifts compaired to similar turbos in the garrett range??
My EFR 7064 recovers from shifts around the same as a GT2871R. Pretty good considering the 2871 has a 54mm turbine wheel and the 7064 has a 64mm one.
Gotta love modern turbo tech - a 56lb/min turbo responding like a <45lb/min turbo... its a pretty sweet age when you can go for 25% more power and not loose any response :)
  • Like 1
Has anybody heard of any serious failures with these things in racing conditions? I mean like the behind the scenes kind of thing that doesn't get released till much later on.
In particular the 8374 turbo? Later on down the track were looking at possibly switching to this unit to replace our GT35r's that have been rebuilt god knows how many times.
I haven't seen many Indy Cars drop out this season with engine problems.....
Late getting back to this and Geoff Raicer in particular .<br />There are limits to what you can use on a standard exhaust manifold and I reckon if there were suitable TS IW T3 flanged turbos available the standard manifold mob would be better off .<br />I'm particular and I can't have everything as I'd like it even with a single scroll IW turbo . At the end of the day I probably need more cubes so I can have the stronger low down part throttle torque and less reliance on FI to do the job properly .<br />
For next time Geoff check this thread:
Will the .80 divided housings only be for B1 frame turbos or will they do it for the 7064 as well?
I'd be soooo keen for a little smaller housing on my 7064 to get full boost under 3000rpm :woot:
Brad is your 7064 mounted on a standard RB25 manifold and if so can we see some pics of it . It'd be interesting to see a bolt on one in an R33/34 engine bay .
Cheers A .
It's an SR20 with T4 TS.
Welcome to the thread.
I did look in your sig before I asked the question and wasn't going back a dozen pages to check what you run .
Does anyone here have a 7064 on an RB engine ?
Actually it was on page 61, this is page 64. Thus my commentary.
Most of our RB customers use the 8374. however there is a drift team in southern California "Animal Auto" using RB25 with EFR 7064. here is the motor setup:
Also on their FB page: https://www.facebook.com/AnimalAuto, check the vids from april 11 and may 21, the engine does not sound like most RB25's
I will ask - I do not know the answer to that one
Correct - in the last 2 years all Indycar teams are using off-the-shelf EFR6758 or EFR9180 and zero turbo failures to date
the 8374 is a really, really good turbo, my favorite turbo ive ever had on my RB26. If you are coming off a GT35R you will not be disappointed. We have this available as T3 or Twinscroll T4 IWG right now. (1.05 a/r still has a very long backorder )
  • 1 month later...
Here's a fun little clip (if anyone is familiar with the old High Octane DVDs the sensor of humour and style will be familiar - this is a little tongue in cheek) with an EFR7670 showing it's worth on an E85 fuelled EJ STi WRX: ("700hp" is actually ~450kw @ 4 hubs):
  • Like 2
  • 3 weeks later...
They don't do twins that small, EFR6258 shouldn't be far off in response but would make a crap load more power
Thank you ^_^
A single EFR7670 would however be more responsive and make more power than -9s
Not looking for top end , high 5's low 600 awhp and tears asphalt. Looking at cost for custom exhaust mani to keeping stock and having twins also ^_^ I want that balance instead of just gobs of power on top.
  • Like 1
Thank you ^_^
The single is smaller, more responsive than the twins. 6258 are capable of heaps
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
