Sub boy. Have you ran your car down the 1/4 at all?
Nah, not a big drag racing fan......oh and I'd prob write the gearbox off! (Maybe when I get a sequential ;) )
Was bad enough on the last fun day around the track when it lunched the front diff :)
Edited by Sub Boy32
^ I kinda agree with that. The 0.92A/R housing would just bee too restrictive for such a high revving 'large' motor.
I am personally going to go a 1.05A/R as well, but have also been considering a 1.45A/R. It would be only slightly laggier but I can run the turbo to the edge with no back pressure issues. My engine is only 2.2L.
The 0.92A/R is great on the RB26 (Geoff runs on on his R14) but it is a little too small on my RB30.
Having said that, I've got amazing response and more than enough power for a street car.... :)
It was a bit of a guess when I ordered the turbo, they hadn't even made production then, and no one had used one on a straight six let alone an RB, it took 9.5months from when I ordered it to when it arrived......and it is numbered #13. Haha
  • 4 weeks later...
Lately I've been impressed with some outstanding results with the IWG EFR turbos... I know there has been some doubt and questions about their functionality compared to an EWG -- but all along, BW engineers told me there isnt a big increase in exh flow from the 0.92 to the 1.05 and that we just needed more WG clamping force. I thought they were crazy bc the 1.05's consistently made more boost and consequently more power. However once we started using BW 'higher boost' actuators and Turbosmart's 26psi IWG we saw the boost acting like an EWG with significant gains due to the stiffer WG spring keeping that flapper shut. Most people do not log Exhaust Backpressure and Turbospeed which makes it difficult to assess from far away, but at this point I can confidently say the 0.92 turbos will make more power and more bosot if you ran the 26psi turbosmart IWG or the new efr actuator
fyi - 0.92 a/r and 8374 IWG on a built evoX here: http://www.evolutionm.net/forums/evo-x-dyno-results/702560-2012-gsr-round-3-efr-8374-iwg-711whp-486wtq.html
darng it! Maybe I should've went with the IWG then lol.. well.. i could always try to swap my actual FR EWG mani + 83/74 for the IWG lol
With that said, I think I will be able to offer a fair and interesting comparaison between the 83/74 and PTE 6266 DBB Gen2. Both rated 800hp. same dyno, same tuner, same haltech ecu. same ''built'' rb26 ( we're both on 86.5mm), same exhaust size basicly. Difference beeing mostly the cam ( 250 9.15mm Vs 260 8.9 ) and the turbos.
Yup! just gotta make it run now right? What's the hold up!
Edited by NismoSTune
We will see, I'm pulling the turbo and the manifold off this weekend as the T4 gasket has blown, so I'm going to get a couple of bosses welded on the manifold to test where the Exhaust Backpressure issue is coming from, I have the Turbospeed sensor, and before Full-Race had a Turbospeed conversion module we made one here, it is showing that I'm close to over speeding the turbo as it is. In fairness I can't be 100% how accurate it is (will get a Full-Race one to be sure) but pretty sure it's right.
Is there an even harder BW hard wastegate spring now? As that Forge one is garbage.....
The will be a very interesting comparison! You have the 250s, I assume? Assuming similar turbine housings I'm going to lean towards the 6266 making the bigger numbers with a touch more lag
Geoff. The 8374 and the 9180, are they the same size housings with different sized wheels?
Have you got a side by side comparison? A 8374 is a bloody huge turbo, physically speaking.
  • Like 1
Come on lads - google knows everything :P
EFR7670, EFR8374, EFR9180:
EFR8374 dimensions:
EFR9180 dimensions etc:
What is interesting is they don't say how big the compressor cover is "across" - but it looks bigger, though the 9180 also seems shorter... if anything. Odd.
Has anyone done a BW vs Precision comparison yet? Im speaking the 1000hp+ turbos. Ive been hearing alot of good things about these new Borg's i might get one.
Edited by Tyranus
If you want 1000+hp with EFR turbos -- go twins. twin 7163's is an impressive combination... literally off-the-shelf indycar turbos
If you want 1000+hp with single turbo, then look at the airwerks turbos. keep in mind it can not spool or respond like the small EFR's
yes, had it on display at SEMA - 43psi rated. The forge is not great, but is very popular. I think the turbosmart is a much better actuator and the ability to run 3 springs identically to their EWG is a nice feature.
side by side and externally EFR8374 and EFR9180 turbos are 100% identical. The only difference is the diameter of the rotor pair (wheels) and the machining to suit. They are plug and play for each other, which 8374 are you trying to fit and to what engine?
Borg Warner website also shows they use they same turbo frame size..
correct
Edited by Full-Race Geoff
What about a GTX45R? I know ive gone a lil off topic here just looking at getting a turbo set up which will net me 1000hp atw on a 2.8.
As this is a thread about Borg Warner EFR turbos, perhaps it is not the best place to ask about the GTX turbos.
In saying that, I agree with what Geoff Said. If you want a NASTY 1000+HP setup, look at some twin EFR7163's. You will have big power, with decent response.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
