GCG were able to also advise turbine speeds over 153,000 rpm could cause failure. They reported quite a few failures of the 9180 used in time attack under extreme conditions.
153,000RPM is nothing for a turbo. your stock turbos probably spin hard then that at full boost. There should be no way of exploding turbine wheel at that point. Might be some welding bits fell out of exhaust manifold or things jammed into the turbine housing.
So after BWs mega hours of testing
you're telling us that they are wrong......
I hope this is the case
I'm just passing on what GCG told me. It's not uncommon for Ti wheels to fail in this way. Borg Warner or not. This is why the limit is posted on the compressor map an they actively support the purchase of a speed sensor and road rage gauge. Ti wheeled turbos are certainly more fussy than their inconel cousins. On closer inspection of my turbine wheel it has porous holes noticeable in the surface which doesn't fill me with confidence in regards to expansion rates.
This whole failure analysis process is about understanding why my turbo failed after 100km to make sure it doesn't happen again. Im not trying to poo poo the product. I've have already bought a replacement 6758.
Matt
Peter, Please understand the max speed will depend entirely on the diameter of the wheels, it doesn't matter who makes the turbo.
560 m/s is turbo mfg's definition of max wheel speed. This is the same across the board for "maximum tip speed" -- Not krpm which does not factor in diameter. 153k rpm is enough to fail most any gt35R or gt40R sized turbo and can only be acheived with a significant boost leak. unfortunately most people do not accurately monitor turbo shaft speed or EMAP which are 2 critical operating parameters for these engines
Mate's EVO with a Garrett reads off 170,000RPM at 18psi. And that thing's through hundreds of tracks days. 153,000RPM can't cause your wheel to explode.
Peter, your friend's Evo has a very small turbo or his speed sensor is setup wrong. There is no reason any aftermarket garrett turbo on evo should be operating at 170k rpm. it would need to have a small turbo with boost leak.
Edited by Full-Race Geoff
Matt
ImageUploadedBySAU Community1427772038.605493.jpg ImageUploadedBySAU Community1427772475.999362.jpg
was referring to old mate petre
post-49288-14279561108357_thumb.jpgpost-49288-14279561336696_thumb.jpgpost-49288-14279563417955_thumb.jpg
post-49288-14279565241856_thumb.jpgpost-49288-14279565804777_thumb.jpgpost-49288-14279566604959_thumb.jpgpost-49288-14279567264545_thumb.jpg
Inspection of the failed EFR shows the turbine most likely was damaged due to a piece of the turbine housing coming loose. Discoloration around the fragment area shows it separated recently. Comparing the turbine housings there is a vast difference in finishing. Also the turbine discharge area has been revised. The newer version is channeled around me the entire turbine outlet which flutes the wastegate gas. The earlier version channel is only 30% of the outlet. I wonder if this was done due to uneven expansion rates..
I'll have a chat to GCG. I feel I may have a case for refund/rebuild.
Matt
  • 3 weeks later...
If ever a found my EFR 83/74 1,05ewg with type-R cam not responsive enought, can i simply swap a 76/70 1,05 EWG in place on the full-race manifold and expect a more responsive rb26 ?
Also, #2, I have a haltech ECU, would you rather keep your profecb2 EBC that act as a boost gauge at the time or use the EFR boost module and buy the boost solenoid to control boost over the haltech ?
I believe going from the 8374 to the 7670 you will
Need to modify the dump pipe slightly as they're not based on the same frame/housings. It will still fit on the manifold but the exhaust will need to be in a slightly different spot. You maybe should have gone the 8374 in the 0.92 IWG.
maybe... but got a good deal on a EWG setup.. and was told the difference between IWG and EWG was approx. 80whp by Full-race. Not ot mention the problem with the IWG tha tneed to be swapped for a turbosmart unit.. i just went ahead with the EWG deal I found..
#1 as long as youre using 1.05 a/r on the 8374 and on the 7670 -- they should drop in place of each other without any changes other than IC piping coupler and intake coupler to suit. I doubt the 8374 will not be responsive enough on RB26, its a really really good combination
#2 Haltech ECU is very good, it can control the EFR 3 port BCSV or the profec solenoid you already have. We just started to carry the 4 port solenoids also, which is an option to consider
I disagree Piggaz, i dont think he will need to change anything on the hotside between these two turbos
Can I still use my greddy profect just to monitor boost reading ? i like the fact the profec fit in the clock compartment and take zero place while a 52mm gauge will take useless space.
Hi Geoff,
For your RB kit with the 6258s is it possible to use an external wastegate on it ? and why did you go with the internal wastegate set up ? was it just for the utilizing the parts that already came with ?
Thanks
Bummer... I asked last page about fititng issue with the Single manifold for R32.. i was told it was better to fit a single stage P/S pump.. Well the problem is not the P/S, it's the A/C.
If I go with a R33/R34 A/C pump, can i still use my r32 crank pulley and simply adjust the belt ( if needed) or i need to change everything.. maybe I should've of went with the Raw manifold that clear everything. :(
  • 1 month later...
I have one, but I am still waiting on my cylinder head and my manifold for my 83/74 .91 AR IWG turbo now from RAW Brokerage.
I will have pumpgas dyno numbers hopefully before summer, but it will be on a BC stroker motor w/ ported head and mild cams.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
