just washed mine after a run up the mountain on wednesday (was fithly after it)
got a hose onto it and gave the underside a good spray
i cant belive how much mud/dirt/rocks there were stuck under the side skirts and hiding away in the rear bumper
i reckon about 20kg of dirt came off the underside and i dont think it was all from that one trip
Well picked up my first stag yesterday 97 model and has 25t xfour written on the back got cream leather interior the satelite navigation tv screen in it has a full 3.5 inch TBE and hks turbo timer also has 18inch rims look like volks of some sort but gotta pull them off and have a look and the best part is I picked it up
for two grand with 8 month rego any how will be going in next week to have a new crossmember put in as the one in it is twisted and also will be getting a FMIC and injectors and eboost 2 put in and then have a tune done so will let you know how it all goes.
Patrick
nice 1.
finished with the stagea for now. last mod was the r32 gtr front calipers. 249rwkw.
working on doing up a r32 4door gtst sedan, with r30 manual & rb26dett engine.
excited. boat finally brought my container.
tomorrow get to p/up stich mags ($30 pound!).... these will hopefully fit the stagea
grex camshafts, spats strut bar, 6-point roll cage
exhaust temp sensor, turbo timer, bride left hand seat rail
bride drivers chair, apexi power intake piping kit
got all the parts for the rb26 buildup in the cupboard now:
hks oil pump, hks step 2 cam springs, n1 water pump, acl race bearings
hks 87mm pistons, attkd rods, arp bolts, arp main head studs
cometic street pro full gasket kit incl 87mm mls head gasket
tomei sump baffle pickup kit, tomei oil gallery orifice, ati harmonic balancer
greddy timing belt, new idler/tensioner, adjustable intake/exhaust cam pulleys
30-row engine oil cooler, oil filter relocation kit, turbo oil cooler
hks split dump pipes, obx tuned-length manifolds, obx front pipe system, decat flex pipe
fitted wilwood superlite forged 4-piston calipers with 324mm drilled rotors up front.
got to install the external fuel pump and fuel surge tank system, then attack the exhaust
and sort out the seats, weld in roll cage and add to it, fill the belt/seat mounts in (eventually rego for 2seater?)
I changed the timing belt and caused the check engine light to come on.... :D
^^^ oh........pull the globe it will be fine!!! lol
speaking of pulling globes... kidafa not that long ago changed his dash to blue LED's... and didnt put his petrol light globe in properly...
needless to say he got a rather decent mileage to that tank...:D:D
Yesterday:
Hacked up the CF-look centre console plastic to graft an R34 manual shift console onto. But 50% done. All cutting/trimming is done, now I just need to plastic weld it all together and bog up the gaps. Later it all gets covered with some real CF. :bunny: Should be finished by early June.
Touched up/puttied and resprayed my front Aero type M bar.
While I had the bar off, refitted the electric fan in front of the a/c condenser.
Had to remove the FMIC to refit the fan, so I also discovered a 10mm size hole in the intercooler, from a bolt on the chassis rubbing thru. :thumbsup: Fixed it up, refitted and test drove it after. Bit more responsive now :banana:
In the next fortnight, I'll be upgrading my brakes to a 325mm kit. :banana:
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
