Connected an Ipod cable that charges and plays my music through the stereo (some crap aftermarket head unit that came with the car)
Only problem is I must have moved a cable or done something because my airbag light is flashing on the dash! will have to pull it apart and see whats going on! I have no idea what wires it would be though!
Ben.
Just wired up my new JVC DV5500 DVD head unit. Wired it up to the Asuka TV tuner I have. It does some cool things like control USB/iPods and video output of contents and CD details.
DVD video out which goes via the Asuka TV tuner to the Navi screen.
CD details when played via the HU.
I also worked out the piouts from the Xanavi unit so I could still use the unit as a CD player if I wanted. This is the adaptor I made up to suit the line in to the HU from the Xanavi. I just need t ofigure out if the HU has a AV in trigger. If it does I'll be able to wire up the Xanavi to turn the HU on when you power it up to play a CD.
and this is what you get, just like the stock headunit.
I fitted Jetwrecked's old AR-X springs to give me some more lift :) I also played around with taking some photos, most of them didnt turn out as I'd quite like, so I'll have another go at it soon (I was taking the photos for photographic experience rather than for the purpose of highlighting my new ride height, I'll be sure to take some of those soon too!)
I fitted Jetwrecked's old AR-X springs to give me some more lift :rofl: I also played around with taking some photos, most of them didnt turn out as I'd quite like, so I'll have another go at it soon (I was taking the photos for photographic experience rather than for the purpose of highlighting my new ride height, I'll be sure to take some of those soon too!)
wicked photo there, what sort of settings was that on?
and lens too?
lol......high enough for yah....now you know why I wanted to get closer to the earth.
Great shot by the way.
P.S. You got a side on shot so I can see the height for ref....PM me if you want.
P.S.S....I want that grill! :)
Edited by Jetwreck
and lens too?
Cheers :) it was a 30 second exposure (to get the city lights) @ f11, lens was my tokina 11-66 (shot at 11mm) - fired off a handful of speedlite flashes also :)
The height is awesome, I can now actually enter and exit my driveway without causing damage to my kit :) I haven't got a side shot yet, but I'll get one for you soon :(
http://www.nengun.com/unknown/ken-style-st...-aero-kit-21157 - dunno what the shipping will be like, and its sustained some damage, but if you're wanting to do some repairs on it well then its an option :)
you still having a problem.... you should come around one weekend and we can see if we can sort it out for you
Cheers
Andy
Yeha i know huh. i might get around to it soon. otherwise i will just keep sooking about it.
i will be out of work in a few days. so will have time maybe unless i get a job asap. (know anything going?)
Ben.
you removed the glove box didnt you.
Cheers :blush: it was a 30 second exposure (to get the city lights) @ f11, lens was my tokina 11-66 (shot at 11mm) - fired off a handful of speedlite flashes also :(
gotta get me a shorter lens, and a half decent tripod, and a decent flash and many more things
have you tried any rolling shots? if you can hold something around 1/200 or even 1/100 shutter speed steady then they look awesome
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
