Pics of my work for this week.
Shows the Autometer boost gauge I put in Tuesday night and the Turbosmart Dual Stage boost controller missile switch inside the Stagea & the controller itself in the engine bay. On low boost it is set all the way anti-clockwise, hitting 9 psi. On high boost, just under 14 psi. Turbo is factory, so I don't want to go much higher than 14 psi anyway.
I took the Stagea for a road test this afternoon with the new setup up from home at Enoggera to Samford & return. It was fun to say the least. ;)
Now to give the Stagea a wash & polish tomorrow before maybe another hill run. :P
whats your avatar?
iHanso is my PSN id.
Finally found and fitted a limited slip diff for a series one stagea.
To celerbrate went to a historic racing event at Brooklands
After a bit (well a lot actually ) of chatting up one of the marshalls :thumbsup: and yes it was a her . I was allowed to drive onto one of the no go areas and take this pic
Currently being blown up for my lounge wall
Was that an optional Nissan viscous lsd or an aftermarket other brand?
finally got a shift kit installed :cool: car goes 100 times better now. it was the only thing still holding me up, so now its time to crank the boost up and see how close i can get to the 300awkw mark.
Just picked up an rb30 short motor from an r31, for free off another awesome forum member.
WooHoo! Project RB30DET in C34-R and Project RB30DE in R31 Skyline wagon both soon to begin!
Group buy dump pipe, high flow cat & 3 inch exhaust through to first muffler being fitted today.
Going to see what benefit I get out of this before finishing the rest.
I pulled the orange indicator lens and the yellow fog light lensa out of the lights in my front bar. Looks heaps better!
i did that a few weeks ago, did you take out the metal bulb cover from the drivers side one?
it even unscrewed, no need to smash anything unlike what i'd heard
COILOVERS IN LAST NIGHT!!! >.< no more standard suspension! the car doesn't feel like a boat in the ocean any more :P
something interesting to note, all the bumb stops were totally screwed. half of one of them was wedged in the bottom coil of the spring, so i checked the rest of them and with 2, as soon as i lifted the dustcover, they fell out in pieces. with the other one, the bump stop wasn't even there anymore...
8kg front, 6 kg rear, dampner is on half way and it's probably a little too hard for our SHITHOUSE roads.
i used to whinge about roads in qld (especially brisbane city and the northside) but holy crap, adelaide has some absolutely disgusting roads. WHY THE HELL AREN'T THE MANHOLE COVERS, FLUSH WITH THE ROAD FFS?! i'm sure every other place in the WORLD can manage this, yet adelaide can't?
finally got a shift kit installed :P car goes 100 times better now. it was the only thing still holding me up, so now its time to crank the boost up and see how close i can get to the 300awkw mark.
YEW!!! where'd you have it done man?
nice, which coilovers did you go for? i got it done at Western Suburbs Automatics, i'd seen the name pop up a few times on SAU and when i rang the guy he knew what a stagea was and new the gearbox, so that was good enough for me lol. can't argue with the results, instant change from 1st to 2nd and 2nd to 3rd with my setup.
Both sides had metal lens holders in the fog light. I left them in there., just removed the yellow bit.
Awesome stuff. What height do you have it set at?
ended up with the BC Racing BR's, mostly to my own stupidity. not realising that the stag is A Arm and not McPherson, i saw camber tops in the pic and thought, "Hell yes! Front camber adjustment for an extra $100!"
pretty much stock height. the goal was to just get them in last night, haha. i've still got to lift the fmic up so that the bottom pipe doesn't stick so far out of the bottom of the car, before we decide to do anything with height. i personally want it to stay at stock height, but i think the girl has other ideas...
oh, i only had one drivers side, gives you much more spread without it
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
