I dont know the measurements, tbh. I would go out and measure them, but i dont have anything to measure with at the moment :thanks:
It doesn't really feel like it's a huge difference in size though.
Back on topic ...
Changed AFM over with a loaned AFM to try and resolve why my stag hits a 5,000rpm limiter ... misfires all over the place. But didn't eliminate the problem.
I've been going thru the elimination process with:
checked cas timing
replaced plugs and gap
replaced coilpacks
replaced air filter
replaced fuel filter
replaced O2 sensor
replaced MAF
Checked all old plugs and they were an even, nice colour. My A/F Ratio meter is telling me the mixtures are rich up top. But I've touched nothing since my last tune. Try a few more things, then I'll just throw it to the tuners. Hoping to save myself some $$$ first.
On the weekend, I'm also going to check the compression in each cylinder for the hell of it.
will it rev past 5k in neutral? or is the problem under load?
check all your cooler joiners and clamps
sounds like you've got a boost leak somewhere
which means that the afm would see much more air going through the system which could lead to you maxing out the afm voltage which gives you a fuel cut similar to the cut at redline
Got my new rotors and pads on the M35 today.. much better no more warped discs!
I went with just the standard size. DBA 4000 XS on the front with QFM A1RM pads, and RDA slotted on the back with QFM HPX pads. (couldnt believe how small the rear pads are!!!!
seems good so far much better pedal feel have to see how they run through the twisty's :thanks::down: before i can give a good review.
but that will have to wait till there worn in a bit.
heres the pics
front
back
Edited by matty_M35
just gave the stagea a good clean, all ready for the cruise tomorrow. Now i just hope it doesn't rain in the morning!
This is Adelaide, of course it will rain tomorrow :thanks:
yeah i know, forecast for strong winds too, just hoping that they aree tailwinds, so my stag doesn't feel so slow! LOL
I gave mine a wipe over too. Dunno why I bothered, it'll rain in the morning and my efforts will have been for nothing :thanks:
howd the cruise end up boys??
removed my turbo/dump
intake mani
ex mani headsheild
all my water lines
timing belt
rocker covers
.... still no sign of dramas yet.. dreading opening the head up soon!!!
braught 33 brakes, manual console, hand brake.... :D all this bullshit better pay off!!!
I went to start mine this arvo, and my approx. 6 week old battery is DEAD! I only used it on Thursday night, so it's not as if it's been left there for weeks at a time!
Tomorrow or Tuesday I'll take it in for testing and possible replacement under warranty.
Jeez, that's bad!
Started up the Stag yesterday for the first time in a month. Started better than it did back then :banana:
cruise was good, 10 stageas rolled up, killer run thru the hills. it was a good day, bit cold tho
... and don't forget the fallen rocks on Gorge Road :)
Weather was cold and wet, but everyone had a good time and made it from A to B safely in the process.
:banana:
Got home from holidays last night
thought I'd take the stag for a blast,seen as she's been sitting for a week and abit all alone in the shed
went really well,was love getting back behind the wheel
till I popped another cooler literally out the front of my house,in the middle of my street,battery went dead again,called the raa and the fella that came out to help steered my car into the gutter as I pushed and munted one of my rims...
Awesome
Should have left it on and wound the boost up John like we discussed.. laggy highflow and only running 7psi means you get all the crap lag of a big turbo and none of the fun :) it was also running the stock tune so you really can't expect much..
With VCT working my highflow is making 15psi by 3500rpm and now that I don't have a hole in my cooler pipe it pulls much harder :action-smiley-069:
Did you put that split dump pipe on?
Well the rebuilt turbo is starting to spool at 1800 rpm, it is at full boost at about 3000rpm. It is now set at 10psi, which is not only safe for the turbo, but is where the air starts getting too hot, so no point in any higher boost. As I am not interested in chasing max power and doing intercooler and all the the other mods that I would have to, I am very happy as it is. The car with the old engine was making 162kw ATW, now 194kw, (same 4WD Dynopak dyno). The Nistune is a bit of a disappointment, in that it will not control boost. It did allow us to change the A/F ratios though, and some timing etc. It leaves all the negative timing at around 6000 rpm, (and Nistune say they didn't know what this was for), which seems to be where the car always backfires on gear change.
This small upgrade, has made this a far more tractable car, without all the expense. As for it running a stock tune, like I said this makes no difference IF the turbo can't produce power boost anyway. Actually after looking at the dyno sheets the Hi-flow wasn't on max until 4000 rpm! It was bloody awful!
Dyno sheets coming soon, (I forgot them). Then down to the drag track to see how this relates into a 1/4 mile.
The split dump was a waste of time IMO, the back pressure was only 2psi @ 4700rpm. About the same as a good fart!
Edited by Appealing
Edit: CBF. You wouldn't listen in person so I'm not going to bother.
Edited by bubba
Got the ARC FMIC sitting in the garage to go in after the wedding. My Stagea is one of 3 Stageas as my wedding cars. I did install the replacement driver side mirror I got from Import Monster over the weekend. Looking at buying an Apexi SAFC Neo now.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
