haha not off to a good start on the front iv smashed a 17mm socket and and extension on the big bottom bolt, they were 3/8 though im off to repco to get some 1/2 inch stuff. While im here do i need to undo the long bolt on the top arm to get them in and out? or just the one at the base of the shock and the two on the strut tower?
horrace put a socket on it and your breaker bar, position it so you can give it a kick and the sharp all of a sudden torque you will create from booting the breaker bar should get it cracked. Make sure the sockets on nice and square first.
well the 25 boxes and the 33 gtr boxes are pretty much the same
and my mates stock shifter fitted in my rs4s
it should fit
I thought the shifter was different due to having a transfer case hanging off the extension housing.. must be wrong though, haven't looked at one in a LONG while. I did have my RB25 shifter in the RB20 box before I upgraded so I definintely know that works.
Edited by bubba
I already drove your car chris!!
But you don't remember cos you were drunk by the time you finished your conversion....
I'll take it for another spin tho
you just want me to come over so you can try and seduce me again
Homo
Got them all in ok no adjustable arms in yet though, I left them at the heights they came and the front is about stock height and the rear is gangster low lol, I raised the rear a bit and I'll get the front where I want it tomorrow I cbf today.
nah dude, his mum's been asking for you :P
at least that hour long wait in the freezing rain sobered him up a bit before he dropped me home, thanks rod :P
Edited by M I K E
GOT MY m35 ON THE ROAD TODAY!!! finally drove it properly!
f**king totally inlove with it!
goes SOOOOOO much more harder than what i expected, and with the kenstyle/hks coilovers it handles f**kin great!!!!
next to lower the coilovers all the way, and put on 30mm spacers :laugh::D:D:D:D
oh when i was driving the engine light came on. and the car stopped driving and just went to idling!
turned the car off waited a minute all was good.
im pretty sure it had something to do with the accel pedal flipping down and me pushing it flat out lol...
Just got my newly painted V35 wheels on the car :laugh:
Colour is Toyota Pewter. Thanks again Chris (Spoolin'12) for the wheels, though, I paid SIGNIFICANTLY more for the paint than what I was telling you!
Better pics when the sun is shining.
now running RDA slotted rotors and Endless SSY pads up front
Porn! Looks nice. I'm keen to get slotted rotors soon too. Gotta get a tune for 16psi first. :laugh:
What... Me?... Never... :huh:
Okay, time to put my 2.2 New Zealand cents in...
Not many individuals go from a highflow turbo back to a stock turbo and say they prefer it, so this is quite foreign to most and probably the cause of much angst.
Saying you didn't even make 7psi until high up in the rev-range is saying that the setup you had was not ideal, whether it be your tune, boost controller gain etc...
I could go on, but I'm sure it'll just be echoing what others have already said :)
Hi Tim
Just to say it again. Any turbo, no matter what size, or characteristics doesn't provide ANY boost until it is spooled up.
This hi-flow was so slow to spool that is wasn't making any boost under 3000 RPM. I am not saying that what others have done with their cars is wrong.
The big question I had was that if it was making full boost on an RB20 at 3200 (as claimed by the builder), then why would the drift guy have taken it off? I know now that it couldn't have been.
I (stupidly) thought that it would be OK on an RB25. It wasn't. Also I didn't want to shell out another $2000, to put another turbo on.
To be honest I probably wouldn't have even looked at a high-flow if it wasn't offered to me so cheaply ($900). It's still for sale if anyone wants it!
I really only wanted 200kw, and 194 is close enough.
I don't really see it as going backwards, I feel that an increase of 32kw (over the old engine) is great considering all I have done is really have the Nistune installed and tuned. The main reasons (obviously) are a motor with only 54,000kms (instead of 119,000) and a new (rebuilt) turbo and tune.
The dyno charts will show comparisons.
I think that once I post these are up people will find that pretty interesting.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
