got my alignment done
can someone have a squiz and tell me if the messed anything up?
i asked him to dial in as much caster as possible and he seemed confused and said "i don't think you will notice that on road tyres mate"
Thanks
Were you in Tassie?
H
Faark dude, even with my best squint I can't read that properly, hope someone's got better eyes than me. I'll have 6 beers and come back to it.
Around +5 deg 22" left, +4 deg 41" caster; -1 deg camber and +0.5mm toe was optimal on my old r31, and it needed camber/caster adjustable strut tops to get there; obviously there'll be some differences given the rear can also be aligned. How were they adjusting the caster? Are your caster rods adjustable?
On my NM35 they're not...
I.ll scan it in, didn't realise the quality was so bad
Installed an 8 point earthing kit and, yes, including the transmission bracket when earthing an M35 makes a bit of difference to gear shifts (still nowhere near a shift kit obviously)
Edited by iamhe77
dropped mine at the workshop to finally get the revalve kit for the front shocks fitted: hopefully handles like a demon again once I get it back...
All that's left now is to get the roof rail replacement kit fitted and painted, than tidy up the engine bay...
compression test yesterday :(
#1 - perfect :D
#2 - perfect :D
#3 - prefect :D
#4 - perfect :D
at this point I thought I had dodged a bullit and I may just have to replace plug's
#5 - perfect :down:
#6 - F#$king nothing :(:(
P.S.anyone want a cheap root....need cash quickly....spooning after is extra!
Edited by Jetwreck
#1 - perfect :D
#2 - perfect :D
#3 - prefect :D
#4 - perfect :D
#5 - perfect :down:
wang some oil down that bore, if it comes up then its the rings orring lands
if it stays down then its in the head which would mean that you don't have to rebuild the block
rnd 3! the first settings on the front are way off cos i changed the steering rack ends
and aster is adjusted with the stock bushes, you only get a tiny bit of adjustment tho
Edited by pipster11
am i lining it up correctly, does that say -16.96 degrees left and +3.02 Degrees right for caster?
yeah, might ask them about that cos it still pulls a tiny bit to the left (no road camber correction) but i guess they only measured the caster on one side?
Here is my suspension settings recipe. You obviously can't get this amount of castor without adjustable arms so i have adjustable castor arms and adjustable rear camber arms. Can't afford the front camber adjusters at this point. You can get a small amount of adjustment with eccentrtic bushes. The value of lots of castor is straight line stability at high speed. If you can't get as much as you want you want them at maximum and then back off rhs to 1/4 degree less than lhs.
Nissan Stagea RS4T
Front
Caster Left positive 6 degrees
Right positive 5.75 degrees
Camber Left 1.0 degree negative
Right 1.0 degree negative
Toe in Left zero
Right zero
Rear
Camber Left negative 0.5 degrees
Right negative 0.5 degrees
Toe in Left minus 2mm
Right minus 2mm
There has to be an error in the print out. With that much + caster on the left and so little on the right it would be undriveable.
You would probably find your wheel hitting the rear of the wheel arch on the left side and the front of the wheel arch on the right.
Stagea is in the shop getting GPS tracking fitted to compliment the alarm/kill switch/club lock. f**k thieves! :rofl2:
Goes for a dyno tune next week. Aiming for 220-230 awkw from the stock injectors :cool:
Then next is Z32 afm and 550cc injectors.
Stagea is in the shop getting GPS tracking fitted to compliment the alarm/kill switch/club lock. f**k thieves! :cool:
Goes for a dyno tune next week. Aiming for 220-230 awkw from the stock injectors :ninja:
who's fitting up the gps tracking? can ya PM me with a cost, with the amount of imports getting stolen in Adelaide lately, i'd def be keen to get some fitted to my off road stagea!
ready for motor out......1 hours work to remove the whole front of the car....gotta love M35's :)
Good effort! Shit, you dont mess about do you :P Is it repairable, or will you be sourcing a new engine?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
