got my alignment done
can someone have a squiz and tell me if the messed anything up?
i asked him to dial in as much caster as possible and he seemed confused and said "i don't think you will notice that on road tyres mate"
Thanks
Were you in Tassie?
H
Faark dude, even with my best squint I can't read that properly, hope someone's got better eyes than me. I'll have 6 beers and come back to it.
Around +5 deg 22" left, +4 deg 41" caster; -1 deg camber and +0.5mm toe was optimal on my old r31, and it needed camber/caster adjustable strut tops to get there; obviously there'll be some differences given the rear can also be aligned. How were they adjusting the caster? Are your caster rods adjustable?
On my NM35 they're not...
I.ll scan it in, didn't realise the quality was so bad
Installed an 8 point earthing kit and, yes, including the transmission bracket when earthing an M35 makes a bit of difference to gear shifts (still nowhere near a shift kit obviously)
Edited by iamhe77
dropped mine at the workshop to finally get the revalve kit for the front shocks fitted: hopefully handles like a demon again once I get it back...
All that's left now is to get the roof rail replacement kit fitted and painted, than tidy up the engine bay...
compression test yesterday :(
#1 - perfect :D
#2 - perfect :D
#3 - prefect :D
#4 - perfect :D
at this point I thought I had dodged a bullit and I may just have to replace plug's
#5 - perfect :down:
#6 - F#$king nothing :(:(
P.S.anyone want a cheap root....need cash quickly....spooning after is extra!
Edited by Jetwreck
#1 - perfect :D
#2 - perfect :D
#3 - prefect :D
#4 - perfect :D
#5 - perfect :down:
wang some oil down that bore, if it comes up then its the rings orring lands
if it stays down then its in the head which would mean that you don't have to rebuild the block
rnd 3! the first settings on the front are way off cos i changed the steering rack ends
and aster is adjusted with the stock bushes, you only get a tiny bit of adjustment tho
Edited by pipster11
am i lining it up correctly, does that say -16.96 degrees left and +3.02 Degrees right for caster?
yeah, might ask them about that cos it still pulls a tiny bit to the left (no road camber correction) but i guess they only measured the caster on one side?
Here is my suspension settings recipe. You obviously can't get this amount of castor without adjustable arms so i have adjustable castor arms and adjustable rear camber arms. Can't afford the front camber adjusters at this point. You can get a small amount of adjustment with eccentrtic bushes. The value of lots of castor is straight line stability at high speed. If you can't get as much as you want you want them at maximum and then back off rhs to 1/4 degree less than lhs.
Nissan Stagea RS4T
Front
Caster Left positive 6 degrees
Right positive 5.75 degrees
Camber Left 1.0 degree negative
Right 1.0 degree negative
Toe in Left zero
Right zero
Rear
Camber Left negative 0.5 degrees
Right negative 0.5 degrees
Toe in Left minus 2mm
Right minus 2mm
There has to be an error in the print out. With that much + caster on the left and so little on the right it would be undriveable.
You would probably find your wheel hitting the rear of the wheel arch on the left side and the front of the wheel arch on the right.
Stagea is in the shop getting GPS tracking fitted to compliment the alarm/kill switch/club lock. f**k thieves! :rofl2:
Goes for a dyno tune next week. Aiming for 220-230 awkw from the stock injectors :cool:
Then next is Z32 afm and 550cc injectors.
Stagea is in the shop getting GPS tracking fitted to compliment the alarm/kill switch/club lock. f**k thieves! :cool:
Goes for a dyno tune next week. Aiming for 220-230 awkw from the stock injectors :ninja:
who's fitting up the gps tracking? can ya PM me with a cost, with the amount of imports getting stolen in Adelaide lately, i'd def be keen to get some fitted to my off road stagea!
ready for motor out......1 hours work to remove the whole front of the car....gotta love M35's :)
Good effort! Shit, you dont mess about do you :P Is it repairable, or will you be sourcing a new engine?
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
