Well. maybe not today but.
HDI FMIC
slim line electric radiator fan
TurboSmart PB BOV(to be changed soon)
3.5" Dump pipe
Dump Back 3.5" exhaust
8000k Xenons
Greddy Informeter Touch
Ball Bearing Hi flowed Turbo(weeeEEEeeee)
Trans "lock up torque converter"
Trans reversed +/- for tiptronic
iPod compatible PA15-NIS install
Unfortunately it isn't tuned yet, just trying to put together the cash for;
plenum spacer kit(Cam)
Stock BOV
Trans Oil Cooler(Craig)
Walbro Fuel pump
650CC+ Injectors
eManage Ultimate
bigger suction pipe
and we shall see what I get out of this budonkadonk of a car :whistling:
I haven't done as much as others, but its a start right?
HDI FMIC
3.5" Dump pipe
8000k Xenons
Stock BOV
Walbro Fuel pump
650CC+ Injectors
eManage Ultimate
bigger suction pipe
and we shall see what I get out of this budonkadonk of a car :)
@Aaron is that Stage 1....lol! :D
@KV2 - thanks mate.....I cannot even remember writing that list :whistling: ....lucky the wife never found it :) .....ECU has changed now - NISMO/Emanage Ultimate(don't do Haltech) combo and 610cc injectors....motor's a bit broken ATM but should be back on the road later this week and then down for it's final tune!
@Aaron is that Stage 1....lol! :whistling:
Stage 1? what the turbo? i dont know he said something about gt30 fans or. its when i was new to the turbo. so he did it n i paid him lol
and what do you mean stage 1? arent you at stage negative 10 Mr Flinstone? hhaah joking
hey english conversion, gimme gimme
Front was 90mm off the ground. Too low!
I'm contemplating importing some Teins to fix the problem for good. I'm not sure how good the factory shocks are, but the C34's I've been told couldn't stand up to the punishment of 100,000K's + Don't know if the M35 is any different. My car has done 70,000K's, so might be a little life left in the old girl yet?
Mine had 39xxx kays when I bought it & my rear shocks were wallabyted! The fronts were not far behind...
You never know though...
can you do mine too mate? im happy to not pay you :(
It was literally a 20 minute job :D It's been driving me bezerk!
I'm happy to not have you not pay me to not do it? Not? :D
If you want some tape I can probably hook you up. Either that or Con-Tact adhesive backed felt is good for this too.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
