Today I finished a complete coolant flush in preparation for summer, engine bay clean and tidied up some bits and pieces around the car.
Also fitted up a TechTom consult display from a mate small compact jap unit that displays digital speed, water temp, AFR and something else thats slipped my mind. Not 100% sure where ill put it but for know its here:
PS. who else is HATING this new forum format!?
One of the best ebc's but its nothing a $30 turbotech wont do imo.
yeh ive got a little "t-bar" boosty. i was just told that its not good to use coz of weather change. didnt make sense to me seeing as its in a hot engine bay lol.
:O
Ive still got the turbosmart Tboost thing. reckon use that one?
I've got the ProfecBII in my Skyline and the Stagea, good little units, simple to install and set up.
I wouldnt mind an electronic one though.
the profec b IS electronic. unless you were still talking about the turbosmart bleed valve
nah the bleed valve thing. i had it on the car before. then the turbo died. RIP gay ceramic fan.
but i could control it to pretty much exactly what i want. where I hear about these electronic BC's are like you must set warnings and make them 2psi higher than what you want n blah blah blah.
yeah set a warning, and then it can drop the boost if it goes over X level
the gain setting is fun lol but you can get the car on boost faster than a bleed valve can.
hmm you should send me yours so i can test it :whistling:
ok send me an address and $500 and you can borrow it for as long as you like :P
for hire?
Thats pretty strange seeing as i can get a new one for $346.00. I can keep it forever as well lol :domokun:
Wut?
Jase, dude, this forum IS my real life, everything else is just a thin veneer :P
Bit late in the year to be planting out seeds innit? Well, if anyone knows how to get them up and running it will be Chuckie, and i know HE will share the love :thumbsup:
Wut?
Propogation tray and blanket with trinidad scorpion seeds is where its at buddy. Chuckie is not sharing the love, so he's not on my no xmas card list atm.
Dude it`s all about SHARING THE LOVE :3some::kiss::blush:
Stop giving said ppls shit and lend me those rims so i can tee up with the rim repairers? glory training, who cares about glory. lol at eagles not being able to train at subiaco bcos of the mess left after Bon Jovi, or should i say Patersons Stadium.
On a side note, I think I may have to go to Mela in Northbridge for a curry tonight.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
