For the Nismo awesome club- Not really an ideal fitment, but better than stock. good if your std height. Cheap too!
http://www.nissanusa...30S-RNA4010.jsp
mmm.. they are nice and good value.. :)
they are big enough for me
next time it will be larger rolling diameter tyres
Never met a bloke who'd say no to an extra inch...:ph34r:
Edited by Daleo
nah i wont make it there, but i know one of the guys filming it!
tonight, gave jetwreck a hand doing a shift kit to a 350z. fck me did it shift fast!!! and every push of the + and - performed a gear change.
anyway, the owner was VERY happy with the outcome. as you would be.
removed my front prop shaft, car feels better in corners i rekon!
yeh the series 2 valve bodies are already upgraded.
the gear box also rev matches and does all this extra funky shit.
My sisters one is auto and actually chirps second on change, and its amazing and holding revs going down gears.
So, we have a separate gearbox computer right?
Is there any way it would work to swap with the 350z one despite the 2wd/4wd difference?
I would love it if mine changed exactly when I wanted not when it decided it felt like doing it.....
the Trans ecu's in the two cars talk to the Cars main ecu. so i dont think going from auto 4wd to auto 2wd would work.
going to Manual 2wd on the other hand, should be no problem. as long as the car can be tuned(emanage f-con etc) you should be fine!
but you also have to keep in mind that the 350z is a lighter car, so some of the feel maybe in that.
its funny you mentioned that, i already thought of obtaining a V35 or Z33 TCU and seeing what would happen. Id say a V35 one would be more compatible (within the same years) and may have different programming.
i know the two TCUs i have are slightly different. i might put back my other one
it lightens the drivetrain taking out the front drive shaft. gear changes ARE snappier on mine now
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
