How'd you do the PS? Just lock to lock about 30 times?
I had to do mine, since we were pushing the car around between workshops.
Attesa Plug under the dash. 2 person job- why 3 Iain - dont need to stay in the boot!
I did PS when I did the cooler.
Drain fluid, hook up cooler, top up fluid, done. I didn't dick around with any bleeding procedures, and it works fine.
You didn't drain the rack though, that's where the issue was. It takes hours to get all the air bubbles out of it.
Serviced 'our' non Stagea: a 1.4 SOHC XC Barina.
What a shit job. Sump plus is some POS that needs torx to remove it. Comes off pretty easy with a hammer and chisel though!
And some genius hung the cat in front of the engine, next to the oil filter...
Now that I've had it up on the hoist though, I can see... New exhaust and manifold should do wonders, and I'm sure someone does an induction kit and chip for the Opel and Vauxhall versions. And some sway bars... Oh dear...
Dailys suck teh balls.
I'm fighting a cold idle problem on mine atm. Basically even if the car is hot, the cold idle valve still allows some air flow and I get a high idle. Doesn't help that coolant changes were negleted prior to me, and little things have corroded. Oh, and then I had to do a radiator top hose on it, and its due for a cam belt, clutch, maybe water pump, and dizzy oil seal soon too!
i got a full set of torx bits for the pair of euros i have now. its bit of a PITA that i have a full set of metric sockets and ring/open spanners that i mostly cant use on the cars
It's not the Torx that pisses me off the most, it's the cheap shit sump plug. It was already knocked about when I looked at it, and it was seized and f**ked. Torx just seems completely unnecessary to me. Allan keys ftw!
What have you got?
I'm lucky by comparison! It'll need brakes and tyres in 10,000, but other than that it's pretty good. Thinking I should replace the air filter, no one knows when it was last changed.
Hey Ryan did you wrap your roof this weekend?
Our daily is a little 1998 excel the missus bought new for 12k on road. Still going mechanically strong at 210,000km with only a clutch master, alternator and map sensor being replaced. Still runs the original clutch, brake pads and rotors that that have never needed to be machined. Pads even have 6mm thickness left. I agree not the best cars around but this one has certainly been great value with only the paint letting it down now that it's fading.
Edited by slippylotion
What have you got?
91 Mazda 323. Its a little trooper. still going great, just about to clock over 200k. One family car. Big spends have really only been a set of shocks, and a timing belt/clutch waterpump service, and reco'd shafts in 110,000kms of use. Other than that, done a rad top tank, and pipe, 2 fuel filters, 2 air filters, Gearbox fluid x1, a $14 water temp sensor, some tyres (still going great after 55,000kms! pirelli FTW!) some random relays, a coil pack/leads that weren't needed because we were trouble shooting... and oil and filter every 7000kms. Oh, and some strut top bushes- they were a bit pricey for what they were. Thats off teh top of my head.
I've taken to writing down when I last did stuff to each of them on the beer fridge now for convenience in whiteboard pen. works a treat.
I had a similar reminder system for my Cressida, but it was on the Rad support in permanent marker, White spirits would get most of it off when stuff needed an update.
Nah mate, didn't get to pick it up. Buggered up and got the night for the SAUSA dinner wrong... Will make a new time to pick it up and go again.
I've always heard good things about Excels being good value and bullet proof, not my thing though. Guess that's why the missus bought it and not you!
The XC is my woman's, if I had to buy one myself I would have got a manual at least, preferably a 1.8.
That's a long time to own a car! Sounds like its been good. We had a Laser TX3 rally car at one point, which shared a lot of common parts with a 323/Familia. Good car except the gearbox...
We've got a record of what's been done in the glove box - complete service history since new. Impressive really.
  • 1 month later...
I always thought bbennys car looked great. Wonder why it keeps going up for sale though?
I'm pretty sure Ben moved it on to free up some capital for his business; I don't believe he really wanted to get rid of it. Who knows with the current owner?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
