Be kind to Jason, the poor bugger might have a poor set up on the rear end of his car.
Have you had a wheel alignment since you have owned the car and if so what was the rear camber?
I would be having a good close look at that first as excessive negative camber made mine a pig in the wet when it landed ex-Japan.
  • Replies 44
I reckon get better tyres & fix up the factory camber.. I could smash the pedal on my old 250rwkW R33 in 3rd in the wet and it would barely spin
I was running -0.8mm camber either side (couldn't make it any more neutral) and 255 Kumho KU31 SPTs pumped up to 38 psi and toed in 0.5mm either side.
learn throttle control in the wet lol, I can drive with the shitest tyres that were 100 a side and with 270kw I can make it not slide in the wet just control your foot.
thx man i will
Easy fix. Buy Nismoids Laser and learn Gary's foot control. You will be the bane of wet roads. I can just see you taking corners at 20, 30 or even deadly 40's
lol
Lasers are a lot of things.....cutting edge isn't f**kin one of them!!
I'd argue there. It was the only car that didn't require servicing I've ever known of...
About 18months, drove it within an inch of its life for around 35,000km's and not once did i spend a cent other than petrol :P
this cant be right. i run same kumho's in 265 @38psi. rear camber is -1deg. around 220kw, smash the pedal in 3rd in the wet, and it's on for young and old.
Edited by Munkyb0y
hi all. im totally new in skyline sense.
coz the weather recently , i found my car is really slippery in wet. although in 3 gear around 3000rpm, it still can go side way on a straight line accelerating.
is it normal?
i ve checked my tyre, still in good condition. i was just worrying is it because any inappropriate setting
R33 GTST SeriesII
190kw at 12psi
Falken tyre: F235 R255
thx :P
dude get an alignement good wet/dry tires and dont put your foot down so hard
Put a pair of space savers on ur car and try to negotiate round a bouts in the rain.
I can say this because I'm not on the same roads as u. Maybe u should warn the locals though.
My first car was an 89 ke laser. I loved it. Couldnt kill it. I dont know how it survived untouched
thx man
so which brand r u recommended ?
There's a sticky thread about which tyre to choose. A lot of the higher performance tyres are designed to be great in dry weather and not so good in wet weather.
Look at the street tyres if you want something decent in wet weather, but you should be driving every carefully in wet weather with any tyre, otherwise you won't have the car long...
I second that. Ease off the throttle a little more and granny drive more in the wet regardless of what tyres you run in. Wet = less traction, less traction = less control in an emergency. I throttled harder than normal at the lights once in the wet and my wheels lost traction. I eased off, grannied for the rest of the trip and all was fine again.
He's asking about trying to do the safe thing and get more grip which all of us should be pushing to make sure we have as much control over our cars as possible. He's not some idiot asking to make it easier to fish tail everywhere all the time cause its 'cool' to be a duche... so easy up on the comments on someone who is new and hes trying to do the RIGHT thing.
I had something like this when I first got my line, had a good/expensive set of Potenza's on there and had brillant grip in the dry but as soon as it was a little wet it was bad always loosing traction even under 10kmph/1500-2000rpm if the road was slippery enough.
Check your tyres, there are different types of tyres i.e. ones that perform better in dry/wet situations. Also, check or get your suspension checked out, I had stockies that had tighter springs on the front, therefore making my car dip at the front so the rear was really light and liked to jump around. If your suspension is really worn then this also explains why your having issues with grip as when you loose grip your suspension is suppose to apply force and help hold your wheel to the ground so you have contact with the surface, obviously the more contact you have, the more grip you have.
After I changed my suspension setup + tyres to my liking, I've been in complete control at all times unlike before.
Also, (try this as a temp) if your tyres are pumped up a lot say 38/40psi try lowering them to 33/35psi as the tread will hug the road more meaning you'd have more grip.
PS you may not think of it this way, but getting more grip means the power your engine is making more of it will be going to the road meaning you will be making more power safely. :)
lol
About 18months, drove it within an inch of its life for around 35,000km's and not once did i spend a cent other than petrol :)
I blew the head gasket 3 times in mine and the 4th bottle of sealup didn't fix it. Apparently it doesn't seal oil gallery vs cylinder leaks....only water ones.
I got $40 for it in scrap metal. Well worth it.......still not cutting edge
PS you may not think of it this way, but getting more grip means the power your engine is making more of it will be going to the road meaning you will be making more power safely. :rofl2:
tl;dr
this is no place for serious posting :)
Actually erderr, keep tyres pumped UP, or even UPPER, in the wet. It holds the tread open so it can shed water better.
Back to the OP - what suspension do you have? If you have Japanese "coilovers", the suspension will be quite stiff. This does not allow good weight transfer on acceleration, and the drive wheels will lose traction in the wet. I had a 240Z with VERY stiff rear springs - in the wet, I could spin wheels DOWN Mt Jane (Calder).
I don't know a single person with 190-200rwkw (because they usually have factory turbo still fitted) that can stop it from wheel spinning past 3k in the wet. Tyres will help, wheel alignment will help suspension will help.....it's always going to spin in the wet if you put your foot down.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
