What is the book "Aussie Godzilla" that you are referring to?
Is it a properly published book with ISBN, or does it exist online with a weblink?
Thank you!
Here you go..........
http://www.pitstop.net.au/products/aussie-godzilla--the-r32-gt-r-arrives-downunder/
Cheers,
Bob.
From what I know it was imported before Nissan did?
Wrong colour but worth adm money if right?
From my understanding, only the 3-4 prototypes plus the 100 documented ADM's are worth ADM money.
That said, even the prototypes are debatable.
Some say they are worth more, some say not as much. It's a tricky one I guess.
I know little about the Scuderia cars.
If they are just grey imports before Nissan finalised their 100 cars then that's what they are...... "Grey Imports" and should be priced accordingly.
I don't see why they should bring a premium, let alone ADM money.
Could anyone clarify exactly what they are?
Thanks,
Bob.
Have to find a good second hand unit local (try FS car parts & accessories $50ish)
New appx $850 AUD from Amayama
No Idea if Nissan parts could help you out or be cheaper
Second hand ones are not worth the effort. Better off with a reconditioned item.
My brother has owned 001 of 006 ever made Scuderia R32 GTRs since 1999 I think...it's original as per factory. Jet Silver Metallic :)
Only 6 were made which was sold locally back in 89. It does not carry any ADM parts such as roof aerial, tail lights, side indicators etc.
They were fitted with the n1 body kit (front bar snorkels, bonnet and boot lip) and also has unique Scuderia branded dash, bootlid badge and compliance plate).
If u search the SAU rare skyline thread I did post pics a few yrs ago.
Edited by Marko R1
Not really as they were sold here in Aust with local compliance. The changes on the Scuderia are not really far off the JDM, but then again the ADM is also not far off from the JDM which I think makes the Scuderia as valuable as the ADM...then again, Its probably the rarest R32 GTR which might even outweigh the ADM.
Edited by Marko R1
Yeah Scuderia in VIC imported them and sold here as new. He has full documentation and the service log was a joke...7k for a service back in early 90s. My brothers car in particular was sold in 92 as it was on the showroom floor at Scuderia for its first 3 years of its life.
We have had no luck in tracking down the other 5. Ive looked for years on the net with nil result. Probably ended up as race cars hence cannot track them as registered vehicles, or written off
Edited by Marko R1
Just spotted in South Hurstville a maroon ADM with plates 1959CF. Sorry couldn't get a pic...another one for the list which I need to update
OK......... We have a problem with that one.
I ran a check through myRTA rego and history check and that rego comes up as a 2006 Ford Falcon!
Either it had an other states rego plate of the guy is swapping plates to avoid number plate recognition in police cars as the car would be unregistered.
Cheers,
Bob.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
