lol the left side of the map is surge, the right side is when its running too hot.
That plot shows that if you are running 20psi, as long as its not hitting 20psi before 3000rpm and if you dont rev it over 8000rpm you will pretty much be making the most of the turbo.
Chances are that turbo wont be on 20psi by 3000 when using the right size exhaust housing, so its good!
They are not available from an australian distributor yet as garrett australia dont recieve them till January 2011 as far as my knowledge goes.
They are available from US dealers (ATP turbo and realstreetperformance are just 2 that we have found so far)
From this garrett link they keep using the figure 10%:
http://www.turbobygarrett.com/turbobygarre...bochargers.html
So I would say roughly 10% more than what they do now.
old 3076 is rated to 525hp atm, used to be 550hp from memory. new gtx3076 is rated at 640hp which is a 22% increase. seams a little optimistic to me using the same turbine housings but time will tell.
old gt3582 is rated to 600hp, new gtx3582 is rated to 750, 25% more.
Nothing to stop you ordering one from em now ;)
Especially with the dollar in good form
Nothing to stop you ordering one from em now :down:
Sure isnt! Ordering one a GTX3076 for my friends SR next week but ill be waiting till they are here in aus/wa when i buy my gtx35r ;)
Wow so considering i was planning on getting a 3076 and was gonna hit 20psi with 300kw's, so just a guess, but do u think the GTX3076 will be able to hit 350kw's by 20 psi?? Unopened RB25 Neo with supporting mods..
I'm also interested in knowing how GTX3076 performs on an unopened DET neo, but I'd 350kw by 20 psi is impossible without cams on ULP.
350rwkw is ~ 470whp, how much flywheel hp is it? Let's say 530fwhp. To make this power using PULP you have to force around 55lb/min of air down the engine's throat. 20 psi is 2.43 pressure ratio, plot this poing on the compressor map. I'd say compressor efficiency is still pretty good at ~70% at this point.
At 101% volumetric efficiency you will need ~7400 rpm to achieve this flow, at 95% VE it becomes 7800-7900 region, at 90% VE it's going to be 8300rpm.
So either make sure your VE is adequate at this point (cams, etc), or increase boost or rev engine harder. Or use different fuel, like E85.
And I guess for the new 76mm compressor with all that additional flow, .63 turbine housing will really struggle to flow enough exhaust gasses and will create some serious backpressure in the upper rev range. Looks like at least .82 A/R is an imperative from now on for GTX3076
Edited by Legionnaire
What would be the recommended configuration to get if i wanted to get an internal gate gtx3071, should i go 63, 82, or 1.06, and what dump pipe? Wanting maximum response and 250-275kw :(
If you go internal gate, as a minimum get the garrett IW .82 housing. Preferably see if GCG can supply you with a HKS IW .87
Do NOT go .63, the number of issues to name is annoying. Wont hold boost, problems with heat, choke your motor at any decent boost level bla bla bla.
Better yet would be external gate, but everyone has their price.
GL
Wow they are huge increases!
It's going to be interesting to see how these things match up to "typical" installs using the old-spec GT series turbos.
With the increased compressor flow comes the need for increased turbine flow and maybe a touch less low end response. I'm left thinking the bigger 1.06 housings will become more of a common selection depending on engine and turbo combination.
Just taking time to digest it all.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
