+1 for in particular on a rb25 with a 3076 compared to a gtx3076 really need to see if there are benifets after talking about them for a while.
I've been advised that a gtx3071 .7 front .73 rear with 4" inlet is the way to go.
You have been advised wrong mate. That is guess work as it is well known the AVO housing does not have any solid results to back it up. It is also known that the said housing is made for the stock turbo and you will need to have it milled to suit the GT30 core.
Therefore you may expect results somewhat close to what you would get with an OP6 housing on the back of your turbo, AKA f**king terrible. The OP6 wont flow what your going to ask of it and wont hold boost properly, so I do not anticipate the AVO will be much better.
If you are serious, get a GTX3071 with whatever front it bloody comes with and the genuine garrett .82IW rear housing. That is the only way to go if you want it to be internally gated.
Now enough broken record questions and go buy a turbo.
Can you point me to some information I can look at that proves:
"it is well known the AVO housing does not have any solid results to back it up"
Also isn't:
"so I do not anticipate the AVO will be much better"
.... Guesswork in itself? I have been advised for that setup (amongst many options) and was justified as to why.
So back to my first point. Please point me in the right direction justifying: "it is well known the AVO housing does not have any solid results to back it up"
Cheers.
Edited by ShiftyTys
The turbine wheels were designed with a garrett housing so you are compromising turbine flow. If you are determined to go this way then post up the results as soon as you are done.
The good news is it will bolt on to the factory dump pipe.
well been reading through info on these new turbos and only dyno results i have found say they aren't much better than the old gt series
so now im left with what turbo do i want to buy it will be going on my rb26/30 i am currently building hopin for close to 600awhp
should i just go a gt35 or gtx35 or will i need to go gt40 its so bloody confusing reading all this dont want to much lag although anything would be better than the t04r i used to have didnt hit full boost untill 5.5K lol
thinking of trying out the gtx3582r but dunno if its worth it???
im in the same boat as you mate,
i already brought a GT35 T3 1.06 abouth 8 months ago, im running my rb30 on e85 so ive been told i should crack the 400rwkw mark
anyways if i was you i would look at the efr borg warner series..
and sit back for a few weeks a compair results from each turbo etc...
Also isn't:
Cheers.
Let me make things simpler. When I say, does not have ANY, that means you will not find ANY. There are no results from an AVO housing. No results = $700 risk, and yes that is how much they cost.
On the other hand, its about half that for the garrett item that is proven to work.
Your cash, your call, either way I wont be 'justifying' anything.
GL.
GL.
Don't make a statement you can't justify or back up. It wastes the time of people who are after informed and educated answers.
It also puts a negative spin on someones product with no proof.
What is to justify? I said its a gamble as there are no results.
Plain and simple. No results to JUSTIFY buying it.
Facts are, its made for the stock turbo and not for a GT30. You will need to machine it to fit the GT30 core. The AR is relevant to the tiny stock turbo. The wastegate port will be sized to suit the stock turbo. It costs $700. Noone has seen one work or do a good job with the same GT30.
More facts: the garrett .82IW housing is proven to work. It will cost you half of the AVO housing and will not need to be modified to fit. It is designed to work with the turbo you want to use. It can hold the boost you will want to run. It can flow the power the turbo is capable of making.
If you want to argue the point further, please see the hypergear thread.
There are a few AVO housing results around if you search but most don't make the most of the compressors potential from what I have seen with the exception of one outlying high result.
Pretty much this subject has been covered a few times over the years and most people are going to suggest the native housing for the turbine for best results.
+1 :thumbsup:
It's quite simple.
AVO housing is not Garrett housing. There have been a number of results posted over the years that clearly show that butchered/Non-Garrett housings simply DO NOT WORK regardless of the claims.
By all means go and buy a rear housing that is too restrictive & have plenty of issues with it. All the while wondering why it wont perform.
You came here asking for advice, you were given it. If you don't think it's accurate and want believe the people trying to make a profit, then go for it. No one here is going to be wasting their money - only you.
Yea that's what I'm thinking haha so much to choose from yea I had a quick read about them before will wait for results .build won't be don't for a few weeks yet anyway is a .82 capable of 400awkw?
I made 427rwkw at 26psi.
+1 :thumbsup:
It's quite simple.
I need proof. I don't just listen and agree. Can't anyone point me in the direction of facts? A thread perhaps? I've done a search for well over an hour and found nothing negative. In fact I pmd a user with and Avo .73 on his gt3076r (pretty much same as gtx3071r) and he loves it.
He described how the power came on and when because he own one. No one else here can tell me the negatives to such detail. Just "it's not original garrette. It won't be as good".
That's not good enough in my book. "not tested enough to know an answer" etc is fair enough however.
Lets put it a more logical way - why do you want to go with the Avo .73a/r housing when there is a housing option which is proven to get the most out of the GT3076R which comes with the turbo? For all I can tell you want to do it just because, because there is no logical reason I can think of. The turbo comes with the Garrett housing, its easy to get a dump pipe made up for it, and most importantly you KNOW its going to work.
Not saying the Avo housing won't - but why take the more difficult and expensive option when there is a known quantity? It doesn't make sense to me.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
