You gotta wonder why mgmt even let's them do stuff like that in the off season.
McLaren prolly keep Lewis in cryostasis, Han Solo-style, in between media/training gigs during the northern winter.
poor kube. that is devastating, could even be career ending for him. :( yeah It's surprising more teams don't have clauses in the contracts stating what drivers can and can't do in their off season. look at webber and his farken endurance events. how well has that worked....not. great way to start a season recovering from a few broken bones.
I mean if you really want to do tarmac rally, or mountain biking etc surely it can wait till after your (short) F1 career? isn't driving F1 cars for 9-10 months a year excitement enough. I would think you would not want to do anything to jeopardise the small window any driver has in F1.
Anyway, I'll be praying for you (or whatever I do in place of prayer) Kube. Hope to see you back on track soon and in a decent car too. bobby kube is without doubt one of the best prospects in the current crop of 'young' drivers and this time out will hurt his progress badly. :(
yeah agreed the testing bad sucks but I'm with stinky. I would not want my mega buck F1 drivers doing tarmac rallies on their time off. the stats tell you the chance of damage is high.
geeebus!! (and ouch)
why is it everyone seems to hit the end or guard rails??? see it on highway crashes too. there can be 100's of km's of nothing, then as soon as you add a guard rail someone will hit it. even if they extend the guard rail after the first one. the next car will hit it earlier.....are they magnetic? or are most people just that scared of em that they end up staring at them till they hit it??? (obv this wasnt the case with Kube)....but.....weird
+1 for the HRT car. looks the busines, love the way its advertising where you can buy advertising
Edited by boiracer
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
