I've seen races where they race in rain just like that, but I think what they mentioned being different was the amount of spray from the tyres and limited visibility as a result from the poor drainage on this particular track.
Wow, what a race! Despite rules and regs trying to ruin it as usual!
So glad to see JB win and hamilton get reminded that going for every gap gets a good percentage of wall, Button had no reason to yield to him.
Vettel must be happy, overall he extended his lead over his main rivals, who didn't finish. Now he's on 161 points, with JB on second 101. He just needs a few DNF's and this championship will be interesting again.
So sad that the fia do everything possible to fk the good races. Still a bit dirty about being robbed monaco quali and gp finale's.
Fuck you kunce that didn't respond.
I booked it.
Look out for me on TV, kents
I may be there for the race. Waiting for a friend to confirm. I am a 100% starter the following weekend in Hungary.
What did you end up doing for accom? Imagine its exxy. You in a stand ir general admussion?
Get on exepedia, we got the night of quali and the race for $190 AUD in Cologne. Thats about an hour away from the track and we've got a hire car.
Yeah T12 - nothing special but it's got a screen.
I just bought these for the little one.
cologne is actually a fair hike from nurburgring definitely more than an hour. Troy can attest to that. even in an audi or focus doing an average speed of about 180km/h it's still a hike!
It will be a bit of a mission on race day I imagine. having said that nurburg is a little hick town in the mountains with nothing much going on after the sun goes down (may be different on a GP weekend though with the big new linder hotel there) so cologne will be more fun in that regard. and I'm guessing at this stage it's probably impossible to get anything in nurburg anyway. hope you are going to try and drive the nordschleiffe? though it will be fking packed for the week before and the week after the GP for sure. i imagine it'll be a mix of full on traffic jams on the track and long closures while they scrape bikers off the armco.
you will love it though no matter what. :)
I hope the rumors are true and that Webber might be going to Ferrari to race alongside Alonso. It'll do him good instead of being stuck behind 'the prodigal' Vettel.
Where did you hear that
Is there a link somewhere would love it if were true
I said too late.
It's booked.
I'll try the north loop but don't like my chances.
I think the rumour of Hamilton going to RBR in 2013 holds more weight, but it's just that, a rumour. Webber has been linked to Ferrari before, yet nothing ever happens from it
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
