One are hopeless. Cutting to ads when showing Webber's in car lap
Yep. I couldn't believe it. BBC are showing incar of the pole lap which also happens to be an Australian and faking one cut it short to squeeze in a few extra ads. Nice.
I also can't believe the fia are f**king with the rules in the middle of a season. All teams new the rules and built the best car they could within those rules. Changing the rules and enforcing that change mid season is unfair and anti competitive. If they think there's a problem by all means announce a rule change now but to be implemented next season so that everyone can design their new car with that in mind.
cjet; I think it was carbon from exhaust pipe, must have got low and close to the redbull checking out the system....
murray walker sounded Old and sick.
hoping Webber runs 1st from start to finish!
webber drops to 5th on the first lap, and fights his way back to 3rd on the podium.
ricciardo drives well, makes up 6 spots and finishes his first GP
That's a fairly likely scenario. However if Webber leads Vettel through the first lap he has a very good chance of breaking his duck this year.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
