doesn't matter, if Webber got pole he'd just clutch slip and be 8th at the first corner so it's probably better he start back there to keep an eye on the front runners straight up.
did anyone notice Vet's head is about half the size width wise as button/hamilton? he still has time to put on the kg I guess.
from his own mouth
pf1
Daniel Ricciardo: "It feels really nice not being on the back of the grid and finishing ahead of Tonio, which is a small target I had set myself, so I'm happy to have achieved that. But I don't want to stop there, I want to do it constantly and progress in one way or another. It's been a tough weekend having suffered some mechanical problems in yesterday's practice sessions, so we didn't get to run as much as we would have liked today. I was aware that I had to give everything I could in this qualifying session and it's really satisfying to have done a good job. Now we have to wait and see how tomorrow goes but I think we should have a good set-up because we didn't go completely aggressive in qualifying."
new boy dun good.
Can't wait for the race, every time hamilton lines up next to vettel, vettel must be wetting himself
any time anyone is within 100m of hamo on the track they are probably wetting themselves wondering when he will take them out, LOL
No offence to ricci and the HRT crew but once you hit 107% quali time why not bring it in at that point to save the tyres? They're not going to get much better except between teammates and they could have better race pace which I would think is more important....from a team point of view.
pretty sure they will still have pretty much a full range of new tyres. they only did 1 qualifying session after all, so they would've only used 2 sets of tyres at most.
i reakon it was a team thing to help get vettel to win the championship ASAP. once that's done and dusted then i think they might let mark have a chance at winning to make sure they can cement his place at number 2 in the championship (forever number 2, LOL)
just watched vettels pole lap on tv. as the dopes (presenters) mentioned, he spends a lot of time on the limiter on the first straight, and a bit on the back straight.
Didi u see the side by side laps compared with lewis? they are neck and neck and sometimes lewis in front but the second chicane is where vettel gets it
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
