MW should have held that inside line when he diced with Button but skipped across the kerb, he needed to park it on the apex to get Button out of the throttle. He clearly made an error that cost him dearly. I also think he should have taken a more aggressive middle of the track position in that 2nd DRS zone after he got past Button the 2nd time. He pretty much just shouldered arms rather than making Button take an extreme inside line or try to make him drive the long way around. Something more Red Baron style.
Oh well.
$5'er says someone in f1 sabotaged vetel's tyre in the interest of a good show.
My guess is it was ment to be webbs tyre so he could crash into homo and button and leave vetool in the clear you saw burnie and Adrian sucking up cause they f**ked up
Edited by stR33ter
So now all is clear why Webz race was farked :)
"This gave the reigning World Champ the opportunity to learn something new and to participate in his team's Sunday's evening, helping out with Mark Webber's strategy."
"So of course he was disappointed, but he didn't rush to leave the circuit. He hung around to help the team and try and help his team-mate."
He can mess with Webber even from pit wall :)
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
