I actually have a few of the starlet, including a cool wheel spin shot. Check my website over the next couple of days and you should be able to find a few.
Last batch of shots i'm posting up from this texi. I hope everyone enjoyed their skids :)
A big thanks to this sexy man for playing a large part in organising the day.
Where there's skids... there's smoke.
dorry dorry
arse
super skidzilla
fast
Last shot to upload from this round
Texi =
Pffft... the time keepers are just a tarp! The real winrars at texi are those who at the end of the day receive the comments like "wow, you sure put on a smoke show" or "do you hate your car or something?" or "could you loop it any more times in a single run?"
I'm pretty sure the winrar of last texi was Aggro Dave :D
Next time though... lol
More so after the first run: "How did you not blow your engine?" "We saw four different colours of smoke as well as flames!" and finally at the end of the day while the engine drops oil pressure "Told you so"... LOL
OzzyDrifter, which was your ride?
so anyway........
;):) :) PICS ARE UP. HAPPY WEEKEND. PICS ARE UP. HAPPY WEEKEND. PICS ARE UP. HAPPY WEEKEND. PICS ARE UP. HAPPY WEEKEND.:):P :P
PICS ARE HERE.
PICS ARE HERE.
PICS ARE HERE.
If you want higher res you can still order up the DVD.
Hey guys, i was in the blue s13 with the legit L plates on it. I got a lot of videos for the day but a lot of them had either water all over the camera or shocking driving. Made up a vid of some of the good footage from the day. its here - http://www.youtube.com/watch?v=MNPWJ7ZdW14
Tks to all the peeps that helped to sort out the day. The end of the day was the greatest. Got so many runs, look forward to the next one.
Enjoy the vid
Edited by WE4PON
  • Like 1
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
