Point is it is a downgrade from the stock ecu and there is no good reason to buy or use one.
you can get them to work fine with air-con, i had one on my WRX in 1999 with a Gt30 etc , before they did flash tunes, I had one on my r31 with air-con, both drove like stock actually
a good tuner can get a decent result from them
cheers
darren
cheers
darren
exactly mine is fine cold starts sits at 1200rpm warms up and drops down to 880rpm everytime no problem. drives like normal starts fine works fine with my VCT and i dont have to worry about upgrading afm as it does not use one. do you really think all the vl guys and a hell of alot of drag cars use them because they are no good. yes they may not be as good as a PFC and has no where near the amount of features the PFC has but im happy it does the job fine and i got it pretty cheap off a mate who took it off his VLT before he sold it and bought a skyline. maybe one day ill remove it and get something better but until then im happy with it and lets drop the hatred towards the microtechs.
Ah well... To be honest I think most microtech users would be like us. Happy with what the machine does as the end user can hardly tell the difference.
Sort of like a 80 year old that gets an iphone on their grand childs recommendation... The chances the 80 year old will do much beyond answering it when it rings and try to make a call on the odd occasion will be slim. No offence but this would fit the bill for over 80 percent of users on this forum when put into context, it fits my bill and I dont even consider myself an entry level user.
Moving on, this is the Kando thread not the Microtech thread. Back to Kando!
LOL @ microleb!!!!!!!!!
i said it a few pages back but here it is again,
ideal setup for a RB25 would be TD06SL2-20g (10cm) with stock manifold (either weld 40 or 44mm ext gate to manifold or onto rear housing)and it will be kept low mount and sorta stock-ish looking, no need to fork out $1000+ for a top mount manifold.
can either run screamer to atmo or plumb back to the dump/front pipe.
this setup would be the most cost effective and stock-ish looking for at least 280rwkw+
i will be changing to this setup next year at tax time. hopefully my twin turbos will last until then but at the rate its going, i think the turbo seals are going again (only replaced the turbos with 2nd hand units 2 months ago as well :( unless i find decently priced HKS GT-SS or -7/-9s for under $1600 but at this stage, the kando setup is looking very favourable).
This is real confusing I'm looking at the td06l2-20g for my rb25 however stao has been trying to sell me one of his turbos I think by saying that the td06l2 is not a big power maker and nit very responsive I know if your looking for a straight turbo swap for streeter HG is the way to go. Do you think this is true or is stao just trying to sell me one of his units
Well for a kando turbo you need to customise some piping for an external wastegate. Whereas the Hypergear turbo will bolt straight in as its internally gated.
Then you just need to compare the turbo results, this will vary on which turbo of each variety you choose. I have not seen many td06l2-20g results on rb25s so that might be hard. Whereas there are tonnes of Hypergear results to look at.
Obviously Tao is trying to sell you a turbo hes not a charity but I think for sub 300rwkw with the standard manifold, bang for buck is pretty bloody hard to beat.
Let me set something straight...... As much as I respect Stao and his products, saying the TD06SL2 is not a good power maker is total GARBAGE.
For the 11ty billionth time THE T67 AND TD06SL2 ARE THE SAME TURBINE WHEEL....... Meaning Simons 10cm T67 turbine and housing is the exact same turbine and housing you will get on a TD06SL2 10cm.
The difference between the T67 and TD06SL2 is the shaft diameter. The T67 is a TD07 and the TD06SL2 is a.......... TD06! Dont be confused, TRUST used the TD07 shaft with the 'TD06SL2' wheel so they could mate it to a 25G compressor, because the 25G is a TD07 sized compressor.
As for response, a little SR20 will get an SL2 20g on full song before 4000rpm and top out around 300kw. Trent (STATUS) has even shown an SR spooling a 10cm TD06SL2 20g as good as a GT2871R (HKS GTRS).
Ive said it before and I will say it again, if Simon can make something close to the 400kw zone out of the SL2 turbine and 10cm housing, I highly doubt the little 20g compressor will have any heat or restriction problems pumping through the same turbine and housing. The Hypergear stuff is good, but it gets hot. For my daily driver and occasional drag machine I would definitely get a HG. For my weekend warrior and track weapon (I mean part time track) I would get the Kando every time.
Just match it to the Tial 44mm gate and your laughing.
stop confusing people with your knowledge Scott :P
this..
SL2 has a smaller compressor making it a better fit when low mounting..in theory it should also make it more responsive...
Is all you really to know ;)
theres a few youtube videos of a ceffie in thailand or singapore or something with a RB25 running a TD06 20G i believe.
seems to go pretty good and very responsive but no dyno sheets.
obviously in japan there will be more results but not much in the case of dyno sheets etc.
I've asked Trent on numerous occasions to post up some results of the TD06 on a RB25 but looks like he may of missed those posts in this thread.
didn't Dr-Drift run a TD06-20G on his R32 RB25 and it made over 300rwkw or so.
Perhaps there is a sheet of it floating around somewhere on the net.
found it;
TD06-20GL2 Chinese Copy (modified exhaust housing with T3 Flange)
XSPower High Mount T3 Ext Gate S/S Manifold
50mm Chinese External Gate
50mm S/S Screamer Pipe
4" Intake with 4" Pod Filter
Bosch/Nissan Z32 Air Flow Meter
Ok, so took the taxi out to calder for the drags... car has been retune to the tune of 305 rwkw!
Best ET was 12.0 @ 122 mph with a 2.6 60' and sever lack of traction!
flyby video;
http://au.youtube.com/watch?v=WpLIZwDGY4I
turbo;
dyno;
261rwkw @ 16psi & 305rwkw @ 20psi charts;
I wouldnt go off those results, they dont seem to be doing their thing...
Roy has proved the 20g to be the goods too. It gets up and boogies the way we would like it to and all on a little RB20.
FYI there are more abundant 1JZ 20g results.
LOL Shutup Dave, hurry up and get your 20g on, dont make me come down there and repair mustang sally with a sledge hammer and some beer. Do as I say. DO AS I SSSSSAAAAAAAAAAAAYYYYY!!!!!!!!!!!!!!
odd that it had such big boost drop though.. Gate too big maybe?
Or just too chinese...
eD..mustang sally is up and running man, just needs a new windscreen..
Im waiting on scott to weld the housing and hes waiting on me to buy a gate..:D
Nah it doesnt seem too bad, but gate selection could probably compensate for it as you said.
The problem is more likely to be its running an 8cm housing, the 10cm housing was some sort of mythical creature before Kando came along and I highly doubt his copy was a 10cm job. I rekon theres a chance the 8cm might bring the 20g on so early it climaxes before the motor comes into its natural powerband that it just hinders the whole final output like that.
Scott, can you put up some dyno results with the 20g on a 1jz :)
Just youtube 1JZ 20G mate, there are a lot out of japland. As you know Japan doesnt have the forum base we do for tuning.
found it;
turbo;
dyno;
Isnt that graph in hp?
Based on my experience of my car on his dyno makes a lot more sense then the claim of 305rwkws.
The below is my car on an old 235rwkws Racepace tune that equaled about 244rwkws on his dyno. Not long after this I went back to Racepace and we leaned on the tune a little more with 100ron and made a comfortable 260rwkws (track tune) So Based on finding 25rwkws on the Racepace dyno lets call it 245+25rwkws on Dr Drifts dyno....so about 270rwkws
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
