An update on my TD05H-18g adventure:
Installed the Kando T518Z copy today on a SR20DE+T along with a Kando SR20 manifold. The manifold was really high quality for what its worth, changed the entire sound of the car now. The TD05-18g went on without any drama, replacing the OEM S14 T28. All lined up perfect ETC.
The driving experience surprisingly has not changed dramatically. Under 2000rpm there IS a notable loss, however you only notice this when creeping away at those revs. Any level of spirited drive has a near lossless experience.
I would say the T28 is entirely progressive in its delivery, packing its best punch just before 4000rpm. The 18g seems to have equal effect from 2000rpm to 3000rpm, from 3000 to 4000 you get a significant increase in pull from the T28 and at roughly 4000rpm the power comes in thick and strong with a 'full song' effect.
I am very impressed with it so far, am very much looking forward to the full tune with double the boost.
What power are u hoping for Jase?
I have an S14 thats looking to upgrade from stock. Maybe this is what he needs.
Being Nistuned by Unigroup for this one, expecting to see 240rwkw BUT am hoping for over 250.
Have seen a couple of these doing 240rwkw with very respectable boost (16-18psi). As you know Im pretty gung ho so Im going to have them turn up the whick on this one until it starts to cap off.
I would put it as a little laggier than a disco, yet making GTRS power. For the record the delivery absolutely shits all over a GTRS and I'm expecting it will make the same power.
well to give you a idea i had a kando td05h18g on my 180sx sr20det non vct tuned by unigroup on 19psi by 4200rpm and made 231rwkw
^^^thats sounds like HKS 2530 numbers, response samish aswell
cheers
darren
Really? I get the same boost response and more power from the bigger TD06-20G on an RB20 and people are forever telling me the SR spools turbos better then the RB20
Well its typical to what i have personally done and seen on others..Rb20 wise i have no idea, haven't had anything to do with them, i don't even like Rb25's..lol, to laggy... i like
sohc forklift motors..lol
cheers
darren
Edited by jet_r31
What gear and what boost?
This is an old dyno sheet of an old tune...but paints the general picture. This is without en EBC, just straight off the gate with a bleed
But generally speaking I make over 200rwkws from 4,500rpm and in 4th gear the gate opens at 4,000rpm
Well they better be ready to man up because I want more than that lol
was the 8cm i reckon on a few more psi of boost and it would of cracked 250rwkw but i didnt try as i only had 555cc injectors and had it up to 237rwkw same boost but tuner finished up on 231rwkw and it backed it up at wsid quarter mile running a 12.5 at 117.9mph with a shit 60ft of 2.19
when i changed it had barely any preload on the actuator so thats why it was a bit lazy on to boost
so its definately very similar in power output to a t518z which its the same as
my brother made 240rwkw on 21psi but with the greddy t518z
so if you really want to crack 250rwkw be willing to run above 20psi the suggested boost is 1.5bar anyway
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
