Im actually worried the gate might flow to well...if thats possible..cant wait to see how it goes though
mines for a rb25 so im going to go the 10cm housing and external gate as the 8cm will choke
and artz ive also noticed your using a 10mm spacer between the turbo and manifold did you need this or did you do it just to be sure as i thought i read on here you didnt need it
yeah you need it..with the spacer there is about 2mm clearance on the comp cover..
I was hoping the new stainless housings would work on these Kando's, what sise is the turbine, is it larger than a GT30?
http://www.ebay.com.au/itm/Stainless-Steel-Turbine-Housing-HKS-GT3037-Garrett-GT3076R-82-AR-Square-T3-/130599600651?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e6857c20b
61mm turbine wheel in the T67-25g.
so an ever so slight machine and it might work
It came up good, I wonder if you could get some sort of heatproof cover like a turbo beanie to cover the wastegate? I guess you will have a screamer plumbed over the heatsheild soon so it wont really matter, when the cops lift the bonnet you will be screwed. lol.
nah man with a custom bracket the screamer pipe will go under the heat shield as well..
so all you will see is the gate hat...which is unavoidable really..
guess i just have to hope whoever looks under the bonnet doesn't no what tial means..:laugh:
get the td06sl2 20g, it will spool faster and it can flow more than enough
Can you steer me to the proof that this is the case? My experience (which is limited to only two cars) is that the L2 is no better then the normal TD06 turbine. Curious to see some cases/examples where they have spooled better
Some of that ACL heat shield stuff might do the job...
http://www.aclperformance.com.au/prod_heatshield.htm
Hes comparing it to a TD06SH (67mm Inducer)
Pretty sure the old S vs SL2 debate doesnt include the SH now does it? lol hey hey hey cmon cmon cmon (jk)
Just get some black high heat tolerance paint and paint over the top of it
^^yeah i probably will , thats all my engine bay needs more paint...:laugh:
LMAO @ TIAL stealthiness, man you crack me up. I wish we lived nearby -_-
and you can get a TFI brass fitting to put a 5/8 bung on the block from autobahn, its a 3/4 from stock i think!
ok i think it just hit me.. was this post about the brass fitting directed at the oil return??
Ye, has a 1/8" NPT fitting for an oil pressure gauge if you want to fir one there
thought so..but i still dont see where it can fit into the line..
One fitting is the same as the oil feed fitting so I suppose it is meant to go between the oil feed and the block..if it is i will need an adapter to go between the t piece and the fitting in the block..
if I do ,is that a good place to put it..?
ah ok why dont you just not use the T piece and get a sandwich plate for between oil filter and block and put a guage in there that way if you had any issues with the guage it would be a hell of alot easier to get to
I was saying that at autobahn you can buy some brass pieces to replace the return bung into the sump.
The factory RB return bung is massive, but most GT series and MHI turbos run a 5/8 hose diameter (16mm), so if you rock into autobahn they will carry a range of TFI branded brass fittings in various sizes. The chances are they will have one that is the same thread size as the stock RB bung but has a 5/8 hose fitting on it, otherwise they will have a 5/8 bung of whatever thread type and most likely have a screw in piece that reduces the size of the thread.
All in all you buy the new brass piece, bolt it in and get a 5/8 oil resistant hose and your laughing. let me know if u have trouble tracking down those brass bits as I know where I can get em
from kando :
Hi,
AR55 will go faster with higher temp. compressored air.
AR 60 goes around 300 rpm slower, but will get more top end.
We do offer 8cm T3 External gated turbine housing for TD06SL2 turbocharger.
When you confirm it, I will list them on our shop.
Sooo , i've suggested the ar55 cover since it's for a lil 20 :D right choice?
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
