Im actually worried the gate might flow to well...if thats possible..cant wait to see how it goes though
mines for a rb25 so im going to go the 10cm housing and external gate as the 8cm will choke
and artz ive also noticed your using a 10mm spacer between the turbo and manifold did you need this or did you do it just to be sure as i thought i read on here you didnt need it
yeah you need it..with the spacer there is about 2mm clearance on the comp cover..
I was hoping the new stainless housings would work on these Kando's, what sise is the turbine, is it larger than a GT30?
http://www.ebay.com.au/itm/Stainless-Steel-Turbine-Housing-HKS-GT3037-Garrett-GT3076R-82-AR-Square-T3-/130599600651?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e6857c20b
61mm turbine wheel in the T67-25g.
so an ever so slight machine and it might work
It came up good, I wonder if you could get some sort of heatproof cover like a turbo beanie to cover the wastegate? I guess you will have a screamer plumbed over the heatsheild soon so it wont really matter, when the cops lift the bonnet you will be screwed. lol.
nah man with a custom bracket the screamer pipe will go under the heat shield as well..
so all you will see is the gate hat...which is unavoidable really..
guess i just have to hope whoever looks under the bonnet doesn't no what tial means..:laugh:
get the td06sl2 20g, it will spool faster and it can flow more than enough
Can you steer me to the proof that this is the case? My experience (which is limited to only two cars) is that the L2 is no better then the normal TD06 turbine. Curious to see some cases/examples where they have spooled better
Some of that ACL heat shield stuff might do the job...
http://www.aclperformance.com.au/prod_heatshield.htm
Hes comparing it to a TD06SH (67mm Inducer)
Pretty sure the old S vs SL2 debate doesnt include the SH now does it? lol hey hey hey cmon cmon cmon (jk)
Just get some black high heat tolerance paint and paint over the top of it
^^yeah i probably will , thats all my engine bay needs more paint...:laugh:
LMAO @ TIAL stealthiness, man you crack me up. I wish we lived nearby -_-
and you can get a TFI brass fitting to put a 5/8 bung on the block from autobahn, its a 3/4 from stock i think!
ok i think it just hit me.. was this post about the brass fitting directed at the oil return??
Ye, has a 1/8" NPT fitting for an oil pressure gauge if you want to fir one there
thought so..but i still dont see where it can fit into the line..
One fitting is the same as the oil feed fitting so I suppose it is meant to go between the oil feed and the block..if it is i will need an adapter to go between the t piece and the fitting in the block..
if I do ,is that a good place to put it..?
ah ok why dont you just not use the T piece and get a sandwich plate for between oil filter and block and put a guage in there that way if you had any issues with the guage it would be a hell of alot easier to get to
I was saying that at autobahn you can buy some brass pieces to replace the return bung into the sump.
The factory RB return bung is massive, but most GT series and MHI turbos run a 5/8 hose diameter (16mm), so if you rock into autobahn they will carry a range of TFI branded brass fittings in various sizes. The chances are they will have one that is the same thread size as the stock RB bung but has a 5/8 hose fitting on it, otherwise they will have a 5/8 bung of whatever thread type and most likely have a screw in piece that reduces the size of the thread.
All in all you buy the new brass piece, bolt it in and get a 5/8 oil resistant hose and your laughing. let me know if u have trouble tracking down those brass bits as I know where I can get em
from kando :
Hi,
AR55 will go faster with higher temp. compressored air.
AR 60 goes around 300 rpm slower, but will get more top end.
We do offer 8cm T3 External gated turbine housing for TD06SL2 turbocharger.
When you confirm it, I will list them on our shop.
Sooo , i've suggested the ar55 cover since it's for a lil 20 :D right choice?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
