A full 60-1 is a T04S, nothing special... However I dont know why Kando trys to sell so many of them or in what application they would work well.
Interesting I guess... Im sure there are still old tech Garretts that whoop ass and take names.
Lithium it seems to me your talking about the 60-1 which is not a trust spec turbo but a cheap Garret spec may e the kando Garret spec turbos ate no good but there has not been a problem yet over with a trust spec turbo hence why this thread is about 60 pages big
Are they straight up component failures Lith?
or other factors involved?
from what i have been told, dumb assembly problems and sometimes the clearances are a bit ho hum , the actual parts used to make them are very good
so your basically taking your chances whether you get a monday or a friday turbo, unless you spend up to $200 ish getting them all mickey mouse.
apperently S@J who do subaru work here in adelaide have bought hundreds of them, so i was told.
cheers
darren
Edited by jet_r31
How many 98 octane tunes with the T67 25G are in this thread..i can't remember is it just the 1 x r33 with converter, what pages are the dyno sheets on if theres others?
cheers
darren
got heaps, average output is 300-330rwkw on 98 std cams and btm end, 340-360 with decent cams.
Fo sho, ill get it out of the car on the weekend. Jez is up on the coast and were in Sydney, so effectively got home some time after 3am and didnt think too much about the graph lol.
We did try to tune beyond the stock AFM resolution but werent having much luck with some ping becoming evident. AFRs were in the low 11s and timing close to 20 up top (from memory). Not sure if its a +T thing or if we could have done something different.
It is very VERY fast, the number is very deceiving (me being a 200kw SR veteran afterall). Might run it up on another known dyno down here.
with 20 degrees it would want to be e85?
So I'm guessing it's going onto a 20 why you going the ls2 and not the h? I have the td06h-20g external gate and see full boost at 4500
VVV that's why
Maybe he will see full boost by 4? Wouldnt that be better?
I mean the 20g is a 300kw compressor, not more. The L2 rear wheel can easily flow 300kw, so that all balances out.
Power is one thing but delivery is King.
Ok , my reasoning for picking the l2 is for the earlier spool , the car it's going in will be used for all different forms of motorsport , i'm not interested in the final number it shows on the dyno more so how it comes onto power and when . Not taking anything away from the H , just after a lengthy discussion with my tuner he/i/we thought the l2 would suit me better :) . The whole 20 setup is only temporary while i'm building the new motor for my car (rb** , i haven't fully decided between 25 or 30 yet , that's pretty much all i'm waiting on for the other motor to be ready) if the turbo fares well i might even put a 10cm housing on the back of it and use it on the other motor for a lil while :)
Boost??, i know i did my head in last night and went through the whole thread, think one post you quoted 345rwkw on 21psi on 98 and 329 on 19psi
edit page 39
Would it be to asking to much to post up some of those big power 98 (standard cam) graphs, to see the power under the curve?
cheers
darren
Edited by jet_r31
You will have to confirm with Jez but I am pretty sure it was up there. It was happy at 17 and pinged at 21, so its somewhere inbetween there.
The turbo was really cruising along, I doubt the charge temp is up there at all (14psi bleeds down to the 12s)
Ok so went on the dyno last night made 242kw with major wheel spin from 5 grand on so can't get a proper reading. There is a restriction somewhere holding it back as well will be playing today im thinking wastegate pipe so is jez so more fab needed will be opening it up to 40mm id pipe and further down the exhaust. Setup is stock rb20 with td06 running 18 pound and your usual breathing mods seeing full boost (on the road) 1st 4800 2nd 4700 3rd 4500 4th 4300 there abouts anyway didn't bother with 5th on the dyno always reads less
Update on my tubro and motor... Did 2 full days of track work at Track Battle in Perth
Ran 20psi and revved anywhere from 7500-8000rpm and it's still loving life!
For anyone counting I also managed a 66.7sec long track which I think is fairly respectable :)
Well dome Simon and good to here still going strong
How was traction...did you get around to changing anything
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
