even with all the issues its looking good man.. :thumbsup:
Ed..just realize you tuned on eflex, Im hoping to make that power on PULP at around 18psi..
just wondering did u use the water lines from the kit and just join them up to some rubber hose as well...its a dodgey setup and i had a time actually getting the fittings to stay tight on the turbo..Im hoping heat will maybe fuse them in place somehow..lol
I always use braided lines, i remove the standard metal part of the coolant pipe from around the back of the head, cut it and get a fitting brazed on. Then i can connect my braided line to it and then refit the metal pipe back into the stock rubber hose behind the head.
This way has always worked well on rb25's but rb20's have a 2 metal brackets behind the head and can be extremely hard to remove
That's an awesome result man. Once you get a decent sized gate on it and wind some boost in youll be laughing.
I think most of these guys havent realised that the turbo should be nowhere near its peak efficiency yet. Not using VCT would be a total bummer and robbing you of response, your boosting it between 11 and 15 psi when they want over 18 to even roll out of bed and your using a mainline dyno which tend to be heart breakers in terms of power.
I think on the right boost it would easily match those figures on 98, given the above. You should have pioneered a 98 tune before you hit teh flexxx. Im about to SMS you too.
Nice result, though the max flow a 20G will give is not a lot over 18psi - I'd not be too surprised if the turbo starts getting way out of efficiency trying to push more boost than that on an RB25, no doubt the E70 will give a bit of headroom for making some more power despite that though. If you've seen cars make more going higher its probably more than the engines need the boost, than the 20G itself.
Will be very interesting to see how it goes with the boost wound up a bit more and the misfire solved, there should be a fair bit more than that to be got yet :)
VCT is disabled in my car so hopefully it doesn't kill too much response.
full boost by 4000-43000 is acceptable :D
very good results so far Jez, i am assured i made the right turbo choice.
i rekon at 20psi, ill pull around 280rwkw and i'll be happy.
try with a lower PSI spring and a better boost controller.
i had this issue with boost not holding on a 38mm turbosmart, installed the 7psi and EBC and all was sweet.
Ebc is Probably needed but its a very low budget car just to show with the right choices what results can be made.
Lithium u are probably right, tho im gonna try 18-20psi anyway :D
Even before i tuned this car properly i could tell by testing it at home that this turbo and combo was impressive. For it to light 3rd gear up without full throttle i was very impressed
SimonR32...care to step in and help out with the wheelspin in 3rd gear AWESOMENESS :)
Great result. Hurry up and give the thing a belly full of boost as I am curious to see what the 20G compressor can flow on E70
Fixed
Thats what this car is built for. Skids
Haha Roy, you are onto it :)
DVS JEZ have a look at my build thread about subframe alignment play around to get power down better.
I think this is a average result but shows a lot of potential when the boost and misfire are fixed... I'm tipping 325rwkw with 15psi in 4th gear on the road at 3200rpm :thumbsup:
Nice. Ill get the vtc sorted too. This car isnt going to be registered so its abit hard to do any on road testing. Ill post up some vids from thursday trackday.
I have a R32 GTR rear cradle but i cant be stuffed to fit it with offset bushes etc. Just wanna drive it.
Great result so far, looking very interesting. My SS1 made 244rwkw on 98 fuel and 279rwkw on Caltex Eflex so everyone can get a rough idea that it would be around 250rwkw on 98 fuel in its current setup. Keen to see what it does with everything sorted!
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
